The AP 6521 is a versatile access point with the cost-efficiency of a single radio. With it’s WiNG 5 intelligence, this access point offers higher throughput along with direct forwarding, security, QoS services and site survivability. The AP 6521 can also serve as a virtual controller and coordinate the operation of up to 23 neighboring access points.
Unique value
The AP 6521 is a multipurpose access point designed to lower the cost of deploying and operating a secure, reliable 802.11n wireless LAN (WLAN) in branch offices or headquarters facilities. The access point features a MIMO radio, superior receive and transmit sensitivity, and a GigE WAN uplink port. The embedded WiNG 5 intelligence ensures that traffic is locally forwarded along the most efficient paths without sacrificing quality of service and security implemented at the access point itself. The AP 6521 can also be used as a sensor for both 2.4 Ghz and 5.0 Ghz frequency bands for multi-band intrusion protection or troubleshooting. -
Automatic channel and power optimization
Common problems such as building attenuation, electronic interference or sub-optimal access point placement are minimalized as the SMART RF feature of the switch/controller automatically optimizes power and channel selection so each user gets always-on high-quality access and mobility. -
High reliability
The AP 6521 is designed to optimize network availability through its central and pre-emptive intelligence which dynamically senses weak or failing signals, securely moves mobile users to alternate APs, and boosts signal power to automatically fill RF holes and ensure uninterrupted mobile user access. -
Gap-free security
Security includes layer 2-7 stateful packet filtering firewall, AAA RADIUS services, Wireless IPS-lite, VPN gateway, and location-based access control. -
Fast and easy deployment
The access ports require no configuration or manual firmware maintenance. The wireless controller discovers access points on the network and automatically downloads all configuration parameters and firmware, greatly reducing installation, maintenance and troubleshooting costs for Layer 2 and Layer 3 deployments. -
Device and network acceleration
Device and network performance can be accelerated through a virtual LAN feature via the switch/controller. Each AP 6521 access point can be virtualized into four unique VLANs which can be customized to direct broadcast traffic to the intended recipient. This reduces overall network traffic while improving device performance and battery life up - to 25%. This also reduces the overall number of access points required to provide unique device services.
- Extreme Networks AP 6521 internal antenna - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- Europe
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 13.97 cm x 15.24 cm x 4.11 cm
- 910 g
- 13.97 cm
- 15.24 cm
- 4.11 cm
- 910 g
- Localisation
- Europe
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Spread Spectrum Method
- OFDM, DSSS
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- Power, error, link/activity
- Auto-sensing per device, DHCP support, VPN passthrough, Intrusion Prevention System (IPS), firmware upgradable, wall mountable, Quality of Service (QoS), RADIUS support, 2T2R MIMO technology, Stateful Packet Inspection Firewall (SPIF)
- Authentication Method
- RADIUS
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45 , 1 x management - RJ-45
- Mounting Kit
- Included
- TUV, EN 60950, UL 60950, IC, FCC
- PoE
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
