Mophie Zagg Rugged Messenger Keyboard Case for Apple iPad 9.7" - Black
Quicklinx: D5WFWS00 Mfr#: I10REU-BBU
The Rugged Messenger keyboard provides you with a laptop-like experience while working on your device. Its tough polycarbonate construction helps protect your investment from drops, the contents of your backpack, and other hazards. With its long battery life, multi-device pairing, and wireless connectivity, the Rugged Messenger gives you the freedom to take your device on the road - for work or play - anywhere, anytime.
  • The world is your workspace
    The whole point of your portable device is to be able to get up and go, right? The Rugged Messenger's wireless, Bluetooth design means you're free to work anywhere without being tied down.
  • Tough enough
    The Rugged Messenger's multi-layered polycarbonate structure is designed to withstand drops! That means, from the table top to the parking lot, you can have peace of mind whether you're catching up on your favorite show or running to catch a ride.
  • Two modes make you mobile
    The Rugged Messenger gives you total versatility when it comes to being productive on the go. Because it has two modes - keyboard and case - you don't need to invest in extra accessories. The stainless steel frame under the keyboard provides a solid surface for typing as well as extra protection for your device.
  • Multi-device for a "multi-life"
    You connect to your world in multiple ways. Multi-device pairing capability lets you connect to two devices simultaneously, such as your phone and your tablet, and switch back and forth between them effortlessly.
  • Looking at it from a different angle
    Magnets in the built-in stand secure your device at multiple viewing angles to accommodate your activities.
  • Type with the ease of laptop-style keys
    Nothing puts your productivity on pause like an awkward, cramped typing experience. The Messenger's improved, responsive keys let you type with the speed and ease of a laptop.
  • Light up the night
    Life doesn't stop when the sun goes down. The keys on the Rugged Messenger are backlit - in seven colors - which allows you to keep going, even in low-light conditions.
ZAGG Rugged Messenger - keyboard and folio case - UK Input Device
Keyboard and folio case
Backlit
7 colours
Bluetooth
Localization and Layout
Hot Keys Function
Power, mute, play/pause, previous track, next track, home page, volume -, volume +, Caps Lock, language key
Black case
Case Material
Polycarbonate, thermoplastic polyurethane (TPU)
24.9 cm x 19 cm x 2 cm
667 g
1-year warranty
Apple 9.7-inch iPad (5th generation, 6th generation)
Backlit
7 colours
Bluetooth
Hot Keys Function
24.9 cm
19 cm
2 cm
667 g
Carrying Case
Material
Adjustable viewing angles, magnetic kickstand
Micro-USB power cable
Rechargeable
Lithium polymer
Limited warranty - 1 year
