The Rugged Messenger Case's layers of tough polycarbonate protection give you with peace of mind whether you're taking your tablet on the road or just surfing at home.
- ZAGG Rugged Messenger Case - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 9.7"
- 19.1 cm x 1.45 cm x 24.7 cm
- 422 g
- Material
- Polycarbonate, thermoplastic polyurethane (TPU)
- 1-year warranty
- Designed For
- Apple 9.7-inch iPad (5th generation, 6th generation)
- 19.1 cm
- 1.45 cm
- 24.7 cm
- 422 g
- Rugged
- Material
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 9.7"
- Protection
- Scratch-resistant, drop-proof
- Cover Type
- Flip cover
- Open Type
- Side
- Closure Type
- Snap closure
- Cover Features
- Stand function
- 1 year
- Designed For
