Never carry a charging cable again. The mophie powerstation plus universal battery combines a compact design, premium feel and built-in switch-tip charging cable that charges both Apple and micro USB devices. This 6,000mAh battery gives you more than two additional charges on your smartphone or will keep your tablet charged longer for more reading. A second USB port lets you charge two devices at the same time. Charging on-the-go is now easier than ever.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
High-output charging
2.1 A output and smart adaptive charging technology identify your connected device and always deliver fast, efficient charging speeds. -
Digital power management
Smart charging circuitry always provides your device with the perfect amount of power for a safe, quick charge. -
Dynamic power & convenience
These low-profile universal batteries feature an elegant design and a built-in switch-tip charging cable with micro-USB and Lightning connectors for added convenience. -
Know before you go
Push the integrated power indicator button to display the charging status and current battery life of your Powerstation. Know before you go.
- mophie Powerstation Plus power bank - USB
- Product Type
- Power bank
- 6.85 cm x 13.37 cm x 1.36 cm
- 160.2 g
- Space grey
- Output Connector Type
- Total 2: USB - on cable: Micro-USB, Lightning
- Max Electric Current
- 2.1 A
- Battery
- 6000 mAh
- Cables
- Micro-USB cable - 22.9 cm , Lightning to micro-USB adapter
- 2-year warranty
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 6.85 cm
- 13.37 cm
- 1.36 cm
- 160.2 g
- Enclosure Colour
- Space grey
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B, Lightning
- 2.1 A
- LED indicator
- Capacity
- 6000 mAh
- Battery level indicator
- Cables Included
- Limited warranty - 2 years
