Talk, play and browse longer than ever with the new mophie powerstation mini universal battery. This 3,000mAh battery will give your smartphone more than one additional charge (or at least one extra charge on your wearable devices). The slim design and premium aluminum finish make this pocket-sized model easy to carry.
mophie products go through rigorous testing. Each battery is tested three times to ensure peak performance and safe operation. This is the reason why mophie is the #1 and most trusted brand in portable power.
The universal power
This classic, compact design with quick charging speeds keeps phones connected through the workday, cameras ready for that next shot, tablets playing movies the entire flight, speakers blasting music even after the party ends, and more. -
Power beyond boundaries
Excellent battery delivers additional hours, giving you the power to do more. -
Ultra-thin design
With a size slim enough for any pocket or handbag, this high-density powerstation battery is still capable of delivering a full charge to smartphones. -
Know before you go
Push the integrated power indicator button to display the charging status and current battery life of your powerstation. Know before you go.
- mophie powerstation mini power bank - Li-pol - USB
- Product Type
- Power bank
- 6.92 cm x 0.85 cm x 11.9 cm
- 90 g
- Black
- Output Connector Type
- USB - on cable: Micro-USB
- Max Electric Current
- 2.1 A
- Battery
- Lithium polymer - 3000 mAh
- Cables
- Micro-USB cable
- 2-year warranty
- Product Type
- Power bank
- Designed For
- Tablet, mobile phone
- 6.92 cm
- 0.85 cm
- 11.9 cm
- 90 g
- Enclosure Colour
- Black
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- 2.1 A
- Power LED Indicator
- Technology
- Lithium polymer
- Capacity
- 3000 mAh
- Material
- Aluminium
- Cables Included
- Micro-USB cable
- Limited warranty - 2 years
