Your basket is empty
Mophie Juice Pack Plus Case + Rechargeable Battery for iPhone5
Need a Mobile Tariff ??? See Description Below
Quicklinx: 93ZTWS00 Mfr#: 2395_JPP-IP5-BLK-I
2100mAh battery case with added power and protection made for iPhone 5. Equipped with up to 120% extra battery to make it through the longest flights or busiest weekends. The juice pack plus is the perfect balance of extra battery power and durable protection from whatever you find yourself getting into. Bring a dead battery back to life while having enough leftover power for when you're still on the move. Surrounding the case is a dual texture, rubberized, shock-resistant band that is still easy to slide in and out of your pocket without sacrificing protection.
