mophie makes wireless charging easier than ever. The wireless-charging juice pack air battery case has the power to extend the life of your iPhone 7 to a total of 27 hours. Use this juice pack case with any mophie charge force wireless mount and enjoy effortless wireless charging at home or in any vehicle as the magnetic mounts hold your phone in place and charging begins on contact. The juice pack case also works on any other wireless charging system, including those found at airports, coffee houses, and in many new cars.
mophie uses advanced wireless and battery technology to create safe, reliable products and deliver the quickest, most efficient charge possible. Charge Vault technology enables the industry-leading, high-density juice pack batteries to hold their charge for an extended period of time so they are always ready right when you need it. Stay Powerful.
All-day power
Smart battery technology offers a safe, quick charge that provides extra battery for the days that don't end when you leave the office. -
Protective yet compact design
Durable outer band, raised bezel edge and rubberized support pads inside of full-case protection guard your phone from drops and hard falls all with a slim design. -
High-impact protection
Durable outer band and rubberized support pads add to the full-case protection for extra security.
- mophie Juice Pack Air - battery case for mobile phone
- Product Type
- Battery case for mobile phone
- 7.122 cm x 1.666 cm x 14.992 cm
- 99.5 g
- Black
- 2-year warranty
- 7.122 cm
- 1.666 cm
- 14.992 cm
- 99.5 g
- Black
Carrying Case
- Battery case
- Recommended Use
- For mobile phone
- Protection
- Scratch-resistant, impact protection, drop-proof
- Wireless Charging Standards
- Qi
- Included Accessories
- USB to micro-USB cable
- Capacity
- 2525 mAh
- 2 years
