A two-way privacy filter on high-quality tempered glass gives you maximum image clarity, remarkable touch sensitivity, and the privacy you need. Super smooth tempered glass, with beveled edges, is unlike anything you've ever felt. Smart EZ Apply tabs make applying your Privacy Glass simple and accurate.
- ZAGG invisibleSHIELD Privacy Glass - screen protector for mobile phone
- Product Type
- Screen protector - with privacy filter
- Intended For
- Mobile phone
- Protection
- Scratch-resistant, impact protection
- Product Material
- Tempered glass
- 7.37 cm 15.5 cm
- Thickness
- 0.03 cm
- Limited lifetime warranty
- Product Type
- Intended For
- Mobile phone
- Protection
- Product Material
- Tempered glass
- 7.37 cm
- 15.5 cm
- Thickness
- 0.03 cm
- Replacement - lifetime , Money back guarantee - 30 days
