Mophie InvisibleShield Glass Curve Elite Galaxy S9+ Case Friendly
Quicklinx: DMSFWS00 Mfr#: 200101467
You can handle any curve that comes your way. Now, so can your phone with Glass Curve Elite. Its full screen adhesive preserves touch sensitivity and ensures that your screen responds to every tap and swipe.
  • Custom, curved fit
    The custom, curved fit of Glass Curve Elite has been specially designed to fit the contours of your screen precisely. And its sleek design is case-friendly. You won't even know it's there - but your phone will.
  • Shock absorbent layer
    A shock-absorbent layer helps prevent the impact of an unexpected drop from shattering your screen.
  • Precision touch sensitivity
    A full screen adhesive solution ensures every inch of your screen responds to your input.
  • Smooth, tempered glass
    Protecting your screen doesn't mean you have to sacrifice its silky look and feel. Smooth, tempered glass feels just like your phone's original screen and provides 100% clarity.
  • Smudge-resistant finish
    Nothing ruins a great Instagram post like a blurry screen. The smudge-resistant surface of the tempered glass wipes cleanly and prevents fingerprints from accumulating.
ZAGG InvisibleShield Glass Curve Elite - screen protector for mobile phone
Screen protector - glass
Intended For
Mobile phone
Protection
Scratch-resistant, impact protection, smudge-proof
Package Content
Screen protector, cleaning wipe, dust removal sticker, microfibre cleaning cloth, EZ Apply tray
Product Material
Tempered glass
Samsung Galaxy S9+
Intended For
Mobile phone
Protection
Package Content
Product Material
Tempered glass
Replacement - lifetime
Samsung Galaxy S9+
