Lyte 10 Multi provides static storage for 10 devices including Chromebooks, laptops and tablets for BYOD users with key pad access on a door-per-device.
Static storage for 10 laptops, tablets or chromebooks up to 15.6" ideal for BYOD deployments
Introducing Lyte! Our static locakable unit with multi door access with individual 6 digit security codes. Ideal for BYOD deployments within the classroom. Stack this together with another Locka unit and aso with the base to allow easy access to all of your devices and store up to 16 laptops, tablets and chromebooks up to 15". -
Cable and AC management
Cable clip portholes secure cables from the side power compartment to the device compartment, to keep cables in place and prevent damage. The IEC power cord plugs in to the mains and are designed to snap out if pulled away from the wall, preventing any damage to the unit or any nasty trips! -
Delivered fully assembled
We also deliver it to you totally fully assembled with non marking feet, so all you need to is plug your devices in and you're up and running! -
Soft start technology
The Lyte features soft start technology meaning the power sequentially starts up power to power strip preventing overloading on start-up (inrush current). -
Simultaneous charge
Charge all 10 devices simultaneously whilst still only using one IEC power cord! -
Small footprint
The small footprint of the Lyte means it can be stored on the floor or on a desk, depending on where you have space. The corner feet lift the unit off the floor to allow for air circulation
- LapCabby Lyte 10 Multi cabinet unit - for 10 notebooks/tablets
- Product Type
- Cabinet unit - floor-standing - lockable
- 52 cm x 52.4 cm x 73.2 cm
- Recommended Use
- 10 notebooks/tablets
- Recommended Display Size
- Up to 15"
- Outlets Qty
- 10
- Material
- MDF, steel
- Limited lifetime warranty
- 52 cm
- 52.4 cm
- 73.2 cm
- Material
- MDF, steel
AV Furniture
- Cabinet unit
- Recommended Use
- Placing / Mounting
- Floor-standing
- Cable Management
- Integrated cable management
- Lockable
- Up to 15"
- Doors Qty
- 10
- Lock Type
- Electronic keypad
- Assembly Required
- No
- Finish
- Powder coated
- Outlets Qty
- 10
Dimensions & Weight Details
- Inner Size
- Notebook compartment - width: 48 cm, depth: 45 cm, height: 5.5 cm
- Limited warranty - lifetime , Limited warranty - electrical components - 2 years
