Product
Monarch Lyte Multi 10
Quicklinx: CQ6YWS00 Mfr#: LYTE10MD
£700.00 ex VAT
£840.00 inc VAT
Lyte 10 Multi provides static storage for 10 devices including Chromebooks, laptops and tablets for BYOD users with key pad access on a door-per-device.
  • Static storage for 10 laptops, tablets or chromebooks up to 15.6" ideal for BYOD deployments
    Introducing Lyte! Our static locakable unit with multi door access with individual 6 digit security codes. Ideal for BYOD deployments within the classroom. Stack this together with another Locka unit and aso with the base to allow easy access to all of your devices and store up to 16 laptops, tablets and chromebooks up to 15".
  • Cable and AC management
    Cable clip portholes secure cables from the side power compartment to the device compartment, to keep cables in place and prevent damage. The IEC power cord plugs in to the mains and are designed to snap out if pulled away from the wall, preventing any damage to the unit or any nasty trips!
  • Delivered fully assembled
    We also deliver it to you totally fully assembled with non marking feet, so all you need to is plug your devices in and you're up and running!
  • Soft start technology
    The Lyte features soft start technology meaning the power sequentially starts up power to power strip preventing overloading on start-up (inrush current).
  • Simultaneous charge
    Charge all 10 devices simultaneously whilst still only using one IEC power cord!
  • Small footprint
    The small footprint of the Lyte means it can be stored on the floor or on a desk, depending on where you have space. The corner feet lift the unit off the floor to allow for air circulation
LapCabby Lyte 10 Multi - cabinet unit
Cabinet unit - floor-standing - lockable
52 cm x 52.4 cm x 73.2 cm
Recommended Use
10 notebooks/tablets
Recommended Display Size
Up to 15"
Outlets Qty
10
Material
MDF, steel
52 cm
52.4 cm
73.2 cm
Material
MDF, steel
AV Furniture
Cabinet unit
Recommended Use
Placing / Mounting
Floor-standing
Cable Management
Integrated cable management
Lockable
Up to 15"
Doors Qty
10
Lock Type
Electronic keypad
Assembly Required
No
Finish
Powder coated
Outlets Qty
10
Dimensions & Weight Details
Inner Size
Notebook compartment - width: 48 cm, depth: 45 cm, height: 5.5 cm
Limited warranty - lifetime , Limited warranty - electrical components - 2 years
Monarch Lyte Multi 10 Bundle deal on Monarch Lyte Multi 10
£799.76
Brand: Monarch
Price Range Ex VAT: 500 - 750
