Monarch LapCabby UniCabby 20H 20 Port Store and Charge
Quicklinx: C6GSWS00 Mfr#: UNI20H
Stock Status: Used Stock
£735.29 ex VAT
£882.34 inc VAT
From our Universal Range, the UniCabby 20H will store and charge 20 iPad, tablet, laptop, Chromebook or a mix of devices up to 14"
LapCabby UniCabby 20H - cart
Cart - lockable
62.6 cm x 51 cm x 118 cm
Recommended Use
20 tablets / notebooks
Outlets Qty
20
Material
Steel
Blue
Wheels Qty
4
62.6 cm
51 cm
118 cm
Material
Steel
Blue
AV Furniture
Cart
Recommended Use
Cable Management
Integrated cable management
Lockable
Wheels Qty
4
Outlets Qty
20
Limited warranty - lifetime , Limited warranty - electrical components - 2 years
Monarch LapCabby UniCabby 20H 20 Port Store and Charge Bundle deal on Monarch LapCabby UniCabby 20H 20 Port Store and Charge
£834.46
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: C6GS 036077
Condition: Customer return - item has been used and shows signs of use. Not in original packaging.
This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is not present or functional  £103.13
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Monarch
Price Range Ex VAT: 500 - 750
