Store, charge and sync 16 devices simultaneously with the portable LapCabby Boost+, suitable for all USB charging Andriod and iOS tablets and mobile phones.
Intelligent Charge for all USB devices
It provides intelligent charging meaning it will provide the exact amount of power required to ensure no over or under charging. -
Device Recognition
It will recognise exactly which device is plugged in to each separate port -
Syncing
Need to sync your devices to make sure they all have your latest updates? The Boost+ will do this simultaneously! -
Connect 2 together to charge and sync multiple devices simultaneously
You have the option to link 2 together so you can charge and sync 32 devices, again, simultaneously whilst still only using one IEC power cord! -
Sleek, ergonomic and portable design
Designed specifically with portability in mind. This lightweight unit is small enough to fit on to desk tops, in to cupboards and only needs one IEC power cord to charge and sync every device -
Upgradeable firmware
Easy to install firmware updates ensure your Boost+ Charge and Sync can charge and sync all of the latest tables, making it future proof
- LapCabby Boost+ charge and sync station - USB
- Product Type
- Charge and sync station
- 28.5 cm x 14.3 cm x 9 cm
- Output Connector Type
- Total 16: USB
- Limited lifetime warranty
- Product Type
- Designed For
- Tablet, mobile phone
- 28.5 cm
- 14.3 cm
- 9 cm
- Input Connectors
- Power IEC 60320 C13, power IEC 60320 C14
- Input Connectors Qty
- 2
- Output connectors
- Total 16: 4 pin USB Type A
- Cambrionix U16S technology, 2 fans
- Limited warranty - lifetime , Limited warranty - parts - 2 years
