Monarch Boost+ for 16 USB Powered Devices
Quicklinx: BQCYWS00 Mfr#: BOOST16CHSYNC
Store, charge and sync 16 devices simultaneously with the portable LapCabby Boost+, suitable for all USB charging Andriod and iOS tablets and mobile phones.
  • Intelligent Charge for all USB devices
    It provides intelligent charging meaning it will provide the exact amount of power required to ensure no over or under charging.
  • Device Recognition
    It will recognise exactly which device is plugged in to each separate port
  • Syncing
    Need to sync your devices to make sure they all have your latest updates? The Boost+ will do this simultaneously!
  • Connect 2 together to charge and sync multiple devices simultaneously
    You have the option to link 2 together so you can charge and sync 32 devices, again, simultaneously whilst still only using one IEC power cord!
  • Sleek, ergonomic and portable design
    Designed specifically with portability in mind. This lightweight unit is small enough to fit on to desk tops, in to cupboards and only needs one IEC power cord to charge and sync every device
  • Upgradeable firmware
    Easy to install firmware updates ensure your Boost+ Charge and Sync can charge and sync all of the latest tables, making it future proof
LapCabby Boost+ charge and sync station - USB
Charge and sync station
28.5 cm x 14.3 cm x 9 cm
Output Connector Type
Total 16: USB
Tablet, mobile phone
28.5 cm
14.3 cm
9 cm
Input Connectors
Power IEC 60320 C13, power IEC 60320 C14
Input Connectors Qty
2
Output connectors
Total 16: 4 pin USB Type A
Cambrionix U16S technology, 2 fans
Limited warranty - lifetime , Limited warranty - parts - 2 years
