Product
Mitsubishi Electric Lamp Module For XL550LP Projectors
Quicklinx: 8PVLWS00 Mfr#: VLT-XL550LP
£307.52 ex VAT
£369.02 inc VAT
Mitsubishi projectors are equipped with a high-pressure, high-voltage mercury lamp. As a result, there may be times that the projector causes "electrical" shock "when touched", a loud noise is emitted if the lamp burns out or the lamp "temporarily" turns off during operation. The differences between these conditions (lamp burning out or "temporarily" turning off) are significant.
Mitsubishi VLT-XL550LP - projector lamp
Projector lamp
Mitsubishi XL550U
Projector lamp
Mitsubishi XL550U
Type: Projector lamp
Brand: Mitsubishi Electric
Price Range Ex VAT: 300 - 500
