Experience the modernised design of the Xbox Wireless Controller in Pulse Red, featuring sculpted surfaces and refined geometry for enhanced comfort during gameplay with battery usage up to 40 hours. Stay on target with a hybrid D-pad and textured grip on the triggers, bumpers, and back-case. Seamlessly capture and share content such as screenshots, recordings, and more with the dedicated Share button. Connect using the USB-C port for direct plug and play to console and PC. Support for
AA batteries is included on the rear. Use the Xbox Accessories app to remap buttons and create custom controller profiles for your favourite games. Plug in any compatible headset with the 3.5mm audio jack. Quickly pair with, play on, and switch between devices including Xbox Series X|S, Xbox One, Windows 10 PCs, and Android. iOS support coming in the future.*
Elevate your game
Experience the modernised design of the Xbox Wireless Controller in Pulse Red, featuring sculpted surfaces and refined geometry for enhanced comfort and effortless control during gameplay with battery usage up to 40 hours.*
Custom mapping
Make the controller your own by customising button mapping.* Plus, plug in any compatible headset with the 3.5mm audio headset jack.
Stay on target
Stay on target with a hybrid D-pad, textured grip on the triggers, bumpers, and back-case. Connect using the USB-C port for direct plug and play to console and PC. Support for AA batteries is included on the rear.
Xbox Wireless and Bluetooth® technology
Includes Xbox Wireless and Bluetooth® technology for wireless gaming on supported consoles, Windows 10 PCs, Android phones, and tablets.* iOS support coming in the future.
Share button
Easily pair and switch
*Important information:
Compatible with select devices and operating system versions; learn more at xbox.com/controller-compatibility. Battery life varies significantly with headsets, additional accessories, usage, and other factors. Testing conducted by Microsoft using standard AA batteries in preproduction units. Button mapping available via Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11; app for Windows requires compatible USB-C cable (sold separately).
Windows 10/11: Requires Bluetooth, compatible USB-C® cable, or Xbox Wireless adapter. Each sold separately. Android, iOS, & Bluetooth: Select devices and versions. Some functionality not supported. Software download may be required via Windows PC or console. See xbox.com/controller-compatibility. Use with controller compatible games. You must accept the Warranty & Agreement at xbox.com/warranty and Software License Agreement at xbox.com/slt.
- Microsoft Xbox Wireless Controller - gamepad - wireless - Bluetooth
- Product Type
- Gamepad
- Connectivity Technology
- Wireless - Bluetooth
- Controls
- D-pad, 2 thumb sticks, triggers, Share button
- Textured grip, Xbox Wireless support, headset port
- Pulse red
- Designed For
- PC, Microsoft Xbox One, Android, Microsoft Xbox Series S, Microsoft Xbox Series X, iOS
- Product Type
- Gamepad
- Controls
- Pulse red
- OS Required
- Windows 10, Android, Apple iOS
- Battery
- Rechargeable
- Designed For
