Microsoft Xbox One Langley Controller with Play and Charger Kit
Quicklinx: CCQMWS00 Mfr#: EX7-00002
Experience the action like never before with the Xbox One Wireless Controller. Impulse Triggers deliver fingertip vibration feedback, so you can feel every jolt and crash in high definition. Redesigned thumbsticks and a D-pad provide greater precision. Plus, keep the action going with the Play & Charge Kit, with a battery that recharges while you play or afterwards, even when your Xbox is in standby.
  • The greatest gamepad - now even better
    The Xbox One Wireless Controller features over 40 improvements to the award-winning Xbox 360 Wireless Controller.
  • More immersive
    Feel the action like never before with Impulse Triggers. Vibration motors in the triggers provide precise fingertip feedback bringing weapons, crashes, and jolts to life for a whole new level of gaming realism. An expansion port with high speed data transfer enables clearer chat audio when using a compatible headset.
  • More precise
    D-pad is responsive to both sweeping and directional movements. Thumbstick improvements enable better grip and accuracy. Trigger and bumpers are designed for quicker access.
  • More comfortable
    Grips and contours have been designed to fit a wider range of hand sizes comfortably. Batteries fit inside the controller body, allowing your hands more room to naturally grip the controller.
  • Always ready
    Charges while you play and when the console is in standby mode. Fully charges in under 4 hours. Say goodbye to disposable AA batteries.
Microsoft Xbox One Wireless Controller with Play and Charge Kit - gamepad - wireless
Gamepad
Wireless
Controls
D-pad, 2 thumb sticks, triggers
Vibration-feedback, headset port
PC, Microsoft Xbox One
Gamepad
Wireless
Max Operating Distance
Up to 5.5 m
Controls
Rechargeable - Lithium Ion
USB charge cable, wireless game controller battery
