Experience the action like never before with the Xbox One Wireless Controller. Impulse Triggers deliver fingertip vibration feedback, so you can feel every jolt and crash in high definition. Redesigned thumbsticks and a D-pad provide greater precision. Plus, keep the action going with the Play & Charge Kit, with a battery that recharges while you play or afterwards, even when your Xbox is in standby.
The greatest gamepad - now even better
The Xbox One Wireless Controller features over 40 improvements to the award-winning Xbox 360 Wireless Controller. -
More immersive
Feel the action like never before with Impulse Triggers. Vibration motors in the triggers provide precise fingertip feedback bringing weapons, crashes, and jolts to life for a whole new level of gaming realism. An expansion port with high speed data transfer enables clearer chat audio when using a compatible headset. -
More precise
D-pad is responsive to both sweeping and directional movements. Thumbstick improvements enable better grip and accuracy. Trigger and bumpers are designed for quicker access. -
More comfortable
Grips and contours have been designed to fit a wider range of hand sizes comfortably. Batteries fit inside the controller body, allowing your hands more room to naturally grip the controller. -
Always ready
Charges while you play and when the console is in standby mode. Fully charges in under 4 hours. Say goodbye to disposable AA batteries.
- Microsoft Xbox One Wireless Controller with Play and Charge Kit - gamepad - wireless
- Product Type
- Gamepad
- Connectivity Technology
- Wireless
- Controls
- D-pad, 2 thumb sticks, triggers
- Vibration-feedback, headset port
- Designed For
- PC, Microsoft Xbox One
- Product Type
- Gamepad
- Wireless
- Max Operating Distance
- Up to 5.5 m
- Controls
- Battery
- Rechargeable - Lithium Ion
- Included Accessories
- USB charge cable, wireless game controller battery
- Designed For
