The all-new Xbox Elite Wireless Controller Series 2 features over 30 new ways to play like a pro, including adjustable-tension thumbsticks, wrap-around rubberized grip, and shorter hair trigger locks. Experience limitless customization with new interchangeable components and exclusive button mapping options in the Xbox Accessories app. Save up to 3 custom profiles on the controller and switch between them on the fly. Swap thumbstick toppers, D-pads, and paddles to tailor your controller to your preferred gaming style. Stay in the game for longer with up to 40 hours of rechargeable battery life and re-engineered components that are built to last. Use Xbox Wireless, Bluetooth, or the included USB-C cable to play across Xbox One and Windows 10 devices. Designed to meet the needs of today’s competitive gamers, the Xbox Elite Wireless Controller Series 2 puts exceptional performance, customization, and durability where it matters most—in your hands.
Play like a pro with the world’s most advanced controller.
Built for performance
Designed to meet the needs of today’s competitive gamers, the all-new Xbox Elite Wireless Controller Series 2 features over 30 new ways to play like a pro. Enhance your aiming with new adjustable-tension thumbsticks, fire even faster with shorter hair trigger locks, and stay on target with a wrap-around rubberized grip.
Optimized for you
Tailor the controller to your preferred gaming style with new interchangeable thumbstick and paddle shapes. Save up to 3 custom profiles and 1 default profile on the controller and switch between them on the fly with the Profile button. Use Xbox Wireless, Bluetooth, or the included USB-C cable to play across your Xbox One and Windows 10 devices. *
More ways to customize
Experience limitless customization with the Xbox Accessories app. Assign a button to act as a ‘Shift key’ to enable alternative inputs for each of the other buttons. *
Designed for extended gameplay
Stay in the game for longer with up to 40 hours of rechargeable battery life and re-engineered components that are built to last. Charge the controller either inside or outside the carrying case with the included USB-C cable and charging dock. *
What’s in the box
Xbox Elite Wireless Controller Series 2, Carrying case, Set of 6 thumbsticks: Standard (2), Classic (2), Tall (1), Wide Dome (1), Set of 4 paddles: Medium (2), Mini (2), Set of 2 D-pads: Standard, Faceted, Thumbstick-adjustment tool, Charging dock, USB-C cable.
*Important information:
Compatible with select devices and operating system versions; learn more at xbox.com/controller-compatibility. Battery life varies significantly with headsets, additional accessories, usage, and other factors. Testing conducted by Microsoft using standard AA batteries in preproduction units. Button mapping available via Xbox Accessories app for Xbox Series X|S, Xbox One, and Windows 10/11; app for Windows requires compatible USB-C cable (sold separately).
Windows 10/11: Requires Bluetooth, compatible USB-C® cable, or Xbox Wireless adapter. Each sold separately. Android, iOS, & Bluetooth: Select devices and versions. Some functionality not supported. Software download may be required via Windows PC or console. See xbox.com/controller-compatibility. Use with controller compatible games. You must accept the Warranty & Agreement at xbox.com/warranty and Software License Agreement at xbox.com/slt.
Optimized for you
Tailor the controller to your preferred gaming style with interchangeable thumbstick and paddle shapes. Save up to three custom profiles and one default profile on the controller and switch between them on the fly with the Profile button. Use Xbox Wireless, Bluetooth or the included USB-C cable to play across your Xbox One and Windows 10 devices. -
Stay in the game for longer with up to 40 hours of rechargeable battery life and refined components that are built to last. Charge the controller either inside or outside the carrying case with the included USB-C cable and charging dock.
- Microsoft Xbox Elite Wireless Controller Series 2 - gamepad - wireless, wired - Bluetooth
- Product Type
- Gamepad
- Connectivity Technology
- Wireless, wired - Bluetooth
- Controls
- D-pad, 2 thumb sticks, triggers
- Vibration-feedback, headset port, interchangeable components, Xbox Wireless support
- Designed For
- PC, Microsoft Xbox One
- Product Type
- Gamepad
- Controls
- Interface
- USB-C
- Battery
- Rechargeable
- Included Accessories
- Carrying case, adjustment tool, 6 thumbsticks, 2 D-pads, 4 paddles, charging station, USB-C cable
- 345 g
- Designed For
