Microsoft Wireless Mouse 900
Quicklinx: BQQRWS00 Mfr#: PW4-00003
Wired / Wireless: Wireless
Compatibility: Mac, PC
24 in stock
£19.86 ex VAT
£23.83 inc VAT
This full-size mouse provides comfortable, precise navigation and has an ambidextrous design that's perfect for use in either hand. It has an amazing long battery life and customizable buttons to give you access to the features you use most.
  • Full-size mouse
    Larger mouse size is designed for greater comfort and more precise navigation.
  • Ambidextrous mouse design
    Mouse is designed to fit comfortably in your right or left hand.
  • Customizable buttons
    Customizable buttons give you access to the features you use most.
  • Long battery life
    Low power consumption provides long battery life based on normal usage.
Microsoft Wireless Mouse 900 - mouse - 2.4 GHz
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6.312 cm x 11.33 cm x 4.41 cm
72.5 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 ppi
Performance
10 G maximum acceleration, 30 inches per second
Scrolling wheel
AA type
Apple MacOS X 10.4 - 10.7, Microsoft Windows 7 / 8 / 10
3-year warranty
Mouse
Wireless Receiver
Orientation
6.312 cm
11.33 cm
4.41 cm
72.5 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 ppi
Performance
Scrolling wheel
1 x USB - 4 pin USB Type A
VCCI, BSMI, ISO 9001, ISO 14001, EMC, MIC, MOC, FCC, R&TTE, NTRA, WEEE, ANATEL, URSEC, NCC, iDA, MSIP, ICASA, TRA, Subtel, ACMA; USB 2.0
AA type
Alkaline
Run Time (Up To)
2 years
Limited warranty - 3 years
5 - 80% (non-condensing)
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
