Microsoft Wireless Mobile Mouse 3500
Quicklinx: 7CX0WS00 Mfr#: 5RH-00001
Recommended Use: Leisure, Mobile
Type: Mouse
Wired / Wireless: Wireless
Colour: Lochness grey
Compatibility: PC
Colours:
More than 50 in stock
£17.29 ex VAT
£20.74 inc VAT
You'll appreciate how this wireless mobile mouse comfortably fits your hand and your mobile lifestyle. Use it just about anywhere, even on a rough park bench or your living room carpet, relying on Microsoft BlueTrack Technology.
When it's time to pack up and go, you'll hardly notice the tiny transceiver. Keep it plugged into the USB port, or stow it in the bottom of the mouse for travel. Keep using your mouse for up to eight months with a single battery, and rely on the power indicator to tell you when it's time to replace it.
Take advantage of BlueTrack Technology, which combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
Plug-And-Go Nano Transceiver
Leave the Nano Transceiver plugged in when you're on the go, or stow it in the mouse.
8-Month Battery Life
Use your mouse for up to eight months without having to change batteries. Battery status indicator tells you when battery power is low.
On/Off Switch
Conserve battery power by turning off your mouse when not in use.
Comfortable in Either Hand
Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
  • BlueTrack technology
    Microsoft BlueTrack technology combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
  • Plug-and-go Nano transceiver
    Leave the Nano transceiver plugged in when you're on the go, or stow it in the mouse.
  • On/off switch
    Conserve more battery power by turning your mouse off when not in use.
  • Comfortable in either hand
    Use your mouse with your left or right hand-ambidextrous design makes it comfortable either way.
Microsoft Wireless Mobile Mouse 3500 for Business - mouse - 2.4 GHz - lochness grey
Mouse
Wireless - 2.4 GHz
Lochness grey
Orientation
Right and left-handed
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, rubber side grips, battery indicator, on/off power switch, Microsoft BlueTrack Technology
Microsoft Windows 7, Windows 8, Microsoft Windows RT, Windows 8.1
3-year warranty
Mouse
Wireless Receiver
Orientation
Lochness grey
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Limited warranty - 3 years
Recommended Use: Mobile
Type: Mouse
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
