Microsoft Wireless Mobile Mouse 1850 Black
Quicklinx: B36JWS00 Mfr#: U7Z-00003
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Android, Mac, PC
Colours:
More than 50 in stock
£10.38 ex VAT
£12.45 inc VAT
The Wireless Mobile Mouse 1850 is designed for life on the go, offering wireless freedom and built-in transceiver storage for ultimate mobility. Comfortable to use with either hand and a scroll wheel for easy navigation makes this mouse the ideal device for your modern, mobile lifestyle.
  • Scroll wheel
    Move through documents and webpages quickly.
  • Comfort and portability
    Compact design to fit in your hand and go wherever you go.
  • Plug-and-go nano transceiver
    Leave the nano transceiver plugged in when you're on the go, or stow it in the mouse.
  • Comfortable in either hand
    Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Microsoft Wireless Mobile Mouse 1850 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
5.81 cm x 10 cm x 3.82 cm
90 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Performance
3000 fps, up to 20 inches per second, 1000 points per inch
Scrolling wheel, Nano wireless receiver
AA type
Microsoft Windows 7, Android 3.2 (Honeycomb), Windows 8, Microsoft Windows RT, Android 4.2 (Jelly Bean), Windows 8.1 RT, Windows 8.1, Apple MacOS X 10.7 - 10.9, Windows 10
3-year warranty
Mouse
Wireless Receiver
Orientation
5.81 cm
10 cm
3.82 cm
90 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 5 m
Optical
Buttons Qty
3
Performance
1 x USB - 4 pin USB Type A
VCCI, BSMI, ISO 9001, GOST, ISO 14001, CB, RSS-210, MIC, FCC, R&TTE, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO, China EIP, CITC, RATEL, NCC, iDA; USB 2.0
AA type
Alkaline
Run Time (Up To)
6 months
Limited warranty - 3 years
5 - 80% (non-condensing)
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
