Microsoft Wireless Mobile Mouse 1850 (Light Orchid)
Quicklinx: CSRTWS00 Mfr#: U7Z-00023
Wired / Wireless: Wireless
Colour: Light orchid
Compatibility: Android, Mac, PC
Colours:
More than 50 in stock
£10.44 ex VAT
£12.52 inc VAT
The Wireless Mobile Mouse 1850 is designed for life on the go, offering wireless freedom and built-in transceiver storage for ultimate mobility. Comfortable to use with either hand and a scroll wheel for easy navigation makes this mouse the ideal device for your modern, mobile lifestyle.
This Microsoft mouse has a plug-and-go nano transceiver which plugs into a USB port, enabling wireless usage at home or on the go. ALL you have to do is plug it in and it's ready for use with no installation required.
The 1850 Mouse runs off one AA battery for up to six months, providing long-lasting use before it needs replacing.
With three programmable buttons, including a scrolling wheel, you can navigate your laptop or desktop with ease when using the Microsoft Wireless Mobile Mouse 1850.
  • Scroll wheel
    Move through documents and webpages quickly.
  • Comfort and portability
    Compact design to fit in your hand and go wherever you go.
  • Plug-and-go nano transceiver
    Leave the nano transceiver plugged in when you're on the go, or stow it in the mouse.
  • Comfortable in either hand
    Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Microsoft Wireless Mobile Mouse 1850 - mouse - 2.4 GHz - light orchid
Mouse
Wireless - 2.4 GHz
Light orchid
Orientation
Right and left-handed
5.81 cm x 10 cm x 3.82 cm
90 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Performance
3000 fps, up to 20 inches per second, 1000 points per inch
Scrolling wheel, Nano wireless receiver
AA type
Microsoft Windows 7, Android 3.2 (Honeycomb), Windows 8, Microsoft Windows RT, Android 4.2 (Jelly Bean), Windows 8.1 RT, Windows 8.1, Apple MacOS X 10.7 - 10.9, Windows 10
3 years warranty
Mouse
Wireless Receiver
Orientation
5.81 cm
10 cm
3.82 cm
90 g
Light orchid
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 5 m
Optical
Buttons Qty
3
Performance
1 x USB - 4 pin USB Type A
VCCI, BSMI, ISO 9001, GOST, ISO 14001, CB, RSS-210, MIC, FCC, R&TTE, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO, China EIP, CITC, RATEL, NCC, iDA; USB 2.0
AA type
Alkaline
Run Time (Up To)
6 months
Limited warranty - 3 years
5 - 80% (non-condensing)
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
