Microsoft Wired Desktop 600 for Business- Black
Quicklinx: C9L3WS00 Mfr#: 3J2-00002
Wired / Wireless: Wired
Colour: Black
Compatibility: Android, Mac, PC
More than 50 in stock
£15.44 ex VAT
£18.52 inc VAT
This desktop set combines a spill-resistant keyboard and optical mouse to deliver all the features you need - and more - with Microsoft quality and reliability. Enjoy plug-and-play setup, Quiet Touch keys with quick access to media controls and calculator, and a comfortable ambidextrous mouse.
  • Media center
    Four hot keys let you control the most-used media activities (play/pause, volume up, volume down, and mute).
  • Quiet-touch keys
    Appreciate a keyboard with quiet, responsive, thin-profile keys.
  • Calculator hot key
    With the touch of the button, you can quickly access the calculator.
  • Spill resistant
    Enjoy a beverage while you work. This keyboard is designed to withstand an accidental spill.
  • Windows start screen key
    Simply press the Windows start screen key to view your apps and start screen.
  • Plug-and-Play
    No software needed. Just connect the keyboard to your PC and go!
  • Comfort
    Experience comfortable use in your right or left hand.
  • Optical technology
    Enjoy high-performance optical technology. The 800-dots-per-inch (DPI) optical sensor delivers greater accuracy and control.
  • Scroll wheel
    Move through documents and webpages quickly.
Microsoft Wired Desktop 600 for Business - keyboard and mouse set - black
Keyboard and mouse set
USB
Input Device
Keyboard
Hot Keys Function
Multimedia, calculator, volume, mute
Pointing Device
Mouse - optical
USB
Dimensions (WxDxH) / Weight
Keyboard: 45.6 cm x 16 cm x 4.27 cm / 595 g , Mouse: 5.79 cm x 11.3 cm x 3.92 cm / 92.8 g
Input Device
Keyboard
Keyboard Name
Microsoft Wired Keyboard 600
Hot Keys Function
Pointing Device
Mouse
Pointing Device Name
Microsoft Basic Optical Mouse v2.0
Movement Detection Technology
Optical
Windows 8.1, Android 3.2 (Honeycomb) or later, Microsoft Windows 7 / 8 / RT, Microsoft Windows RT 8.1, Apple MacOS X 10.7 - 10.9
5 - 80% (non-condensing)
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
