Brand
Microsoft Wired Desktop 600 Black
Quicklinx: 5GCSWS00 Mfr#: APB-00006
Recommended Use: Leisure
Type: Keyboard
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC, Android
More than 50 in stock
£20.00 ex VAT
£24.00 inc VAT
This desktop set combines a spill-resistant keyboard and optical mouse to deliver all the features you need-and more-with Microsoft quality and reliability. Enjoy plug-and-play setup, Windows Vista integration, Quiet Touch keys with quick access to media controls and calculator, and a comfortable ambidextrous mouse.
Mouse Features:
  • Windows Start Button: Press to launch your Start menu and search your PC or the Web if you have Windows Vista installed
  • Plug and Play: No software needed. Just connect the keyboard to your PC and go!
  • Comfort for Either Hand: Use your mouse with your left or right hand--ambidextrous design makes it comfortable either way
  • Optical Technology: Navigate with better speed, accuracy and reliability--the optical sensor tracks movement on nearly any surface without the hassle of clogged mouse parts
  • Scroll Wheel: Move through your documents quickly without having to click on the on-screen scroll bar
Keyboard Features:
  • Media Center: Four hot keys let you control the most-used media activities (play/pause, volume up, volume down, and mute)
  • Quiet-touch Keys: Quiet, responsive, thin-profile keys
  • Calculator Hot Key: With the touch of the button, you can quickly access the Calculator
  • Spill-Resistant Design: Enjoy a drink while you work--this keyboard is designed to withstand an accidental spill
  • Warranty: 3-Year Limited Hardware Warranty
  • Comfort for either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
  • Scroll wheel
    Move through your documents quickly without having to click on the on-screen scroll bar.
  • Spill-resistant design
    Enjoy a beverage while you work - integrated water channels drain liquid away.
  • Optical technology
    Navigate with better speed, accuracy and reliability - the optical sensor tracks movement on a variety of surfaces without clogged mouse parts.
  • Quiet Touch keys
    Type with your hands in a more natural position on the quiet, responsive, thin-profile keys.
  • Media centre
    Control the most-used media activities (play/pause, volume up, volume down, and mute) with four hot keys.
Microsoft Wired Desktop 600 - keyboard and mouse set - UK - black
Keyboard and mouse set
USB
Input Device
Keyboard
Wired
Localization and Layout
Hot Keys Function
Multimedia, calculator, volume, mute
Spillproof
Pointing Device
Mouse - optical
USB
Dimensions (WxDxH) / Weight
Keyboard: 45.6 cm x 16 cm x 4.27 cm / 595 g , Mouse: 5.79 cm x 11.3 cm x 3.92 cm / 92.8 g
Input Device
Keyboard
Keyboard Name
Microsoft Wired Keyboard 600
Hot Keys Function
Spillproof
Pointing Device
Mouse
Pointing Device Name
Microsoft Basic Optical Mouse v2.0
Movement Detection Technology
Optical
2 x USB cable
Windows 8.1, Android 3.2 (Honeycomb) or later, Microsoft Windows 7 / 8 / RT, Microsoft Windows RT 8.1, Apple MacOS X 10.7 - 10.9
5 - 80% (non-condensing)
Type: Keyboard
Colour: Black
Compatibility: Mac
Compatibility: PC
Compatibility: Android
Brand: Microsoft
Stock Status: In stock
