With the Universal Mobile Keyboard, getting stuff done while you're on the go has never been easier. Power through emails, put together a proposal, or instant message with a friend. It doesn't matter if you're on your tablet or your smartphone - the Universal Mobile Keyboard was designed to work with iPad, iPhone, Android devices and tablets. Pair with up to 3 devices with different operating systems and easily switch between them. The compact and light weight design of the Universal Mobile Keyboard was built with portability in mind with its protective cover and built-in stand that holds your tablet or smartphone. Just flip the cover open to power-up and make a Bluetooth connection, then set your device into the integrated stand - you'll be typing in seconds. Shutting down is just as fast. Simply close the cover to turn off the keyboard - it's that easy. The rechargeable battery provides up a months of usage on a single charge. But if you're ever low on power when you're heading out, don't worry - just do a quick charge and you'll have plenty of power for a full day's work. So leave the laptop behind - the Universal Mobile Keyboard lets you get real work done with just your tablet or smartphone.
Multi-purpose cover
The protective cover includes an integrated stand for your tablet or phone. The cover can be detached for more comfortable positioning of your device. -
Open the cover to connect
Simply open the cover to power up and connect. Close the cover to turn off the keyboard. -
Designed for iPad, iPhone, Android devices and Windows tablets
Pairs with up to 3 devices with different operating systems and easily switch between them using the Operating System switch. -
Rechargeable battery
Rechargeable battery provides a few months of usage on a single overnight charge. A ten minute charge provides a few hours of usage. Battery status indicator lets you know when you're low on power. -
Wireless Bluetooth technology
Bluetooth connectivity eliminates the clutter of wires and dongles.
- Microsoft Universal Mobile Keyboard - keyboard - English - grey
- Keyboard
- Interface
- Bluetooth
- Localization and Layout
- English
- Hot Keys Function
- Volume, search, mute, play/pause, previous track, next track
- Protective cover, integrated tablet stand
- Grey
- 24.2 cm x 10.9 cm x 1.2 cm
- 365 g
- 3-year warranty
- Keyboard
- Interface
- Bluetooth
- Max Operating Distance
- Up to 10 m
Input Device
- Hot Keys Function
- English
- 24.2 cm
- 10.9 cm
- 1.2 cm
- 365 g
- Grey
- VCCI, ISO 9001, ISO 14001, IC, MIC, MOC, R&TTE, RoHS, NTRA, KCC, WEEE, ANATEL, TELEC, REACH, Subtel
- OS Required
- Windows 8, Android 4.0 or later, Windows 8.1, Windows RT, Apple iOS 6.0 or later
- Installed Qty
- 1
- Required Qty
- 1
- Technology
- Lithium
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
