Universal Foldable Keyboard is the perfect travel companion - its ultra-thin, lightweight, compact design lets you easily take it wherever you go so you can get more done on your tablet or smartphone no matter where you are.
You can simultaneously pair it with virtually any two mobile devices - an iPad, iPhone, Android devices, Windows tablets, and Windows Phone - and then instantly switch between them with a single touch. Set up in a second - just open it to turn it on and connect. Then you'll enjoy fast, comfortable typing on a full-sized keyboard. Power through emails, edit a proposal or instant message with friends. When you're done, simply close it to turn it off and you're ready to go.
For your tablet and smartphone
Pair the keyboard with any combination of two compatible devices and quickly switch between them with one touch. -
Works across devices
The Universal Foldable Keyboard was designed to work with iPad, iPhone, Android, Windows tablets, and Windows Phone. -
Spill-resistant design
Water repellent keyset and fabric helps protect against accidents. -
Compact, foldable design
Innovative, foldable design lets you easily fit the keyboard into a purse, bag, or pocket. -
Ultrathin and lightweight
Only 5mm thin, the innovative, foldable design easily fits into a purse, bag, or pocket. -
Full-size keyset
The full-size keyset provides fast, accurate typing. -
Easy on/Easy off
Open the keyboard to connect to your tablet or smartphone. Simply close the keyboard to shut it down. -
Rechargeable battery
The built-in rechargeable battery provides up to three months of usage on a single charge. -
Bluetooth Smart
Clutter-free and reliable experience utilizing the latest in Bluetooth technology.
- Microsoft Universal Foldable Keyboard - keyboard - UK
- Keyboard
- Interface
- Bluetooth
- Foldable
- Localization and Layout
- UK
- Keys Qty
- 77
- Hot Keys Function
- Search, mute, screen lock, play/pause, previous track, next track, switching devices, volume -, volume +
- Protection
- Spill-resistant
- Foldable, spill-resistant, Bluetooth 4.0 compatible
- 29.51 cm x 12.53 cm x 1.15 cm
- 180 g
- 3-year warranty
- Keyboard
- Interface
- Bluetooth
- Foldable
- Max Operating Distance
- Up to 10 m
- Dimensions (WxDxH) / Weight
- 1.15 cm
Input Device
- Keys Qty
- 77
- Hot Keys Function
- UK
- Protection
- Spill-resistant
- 29.51 cm
- 12.53 cm
- 180 g
- VCCI, BSMI, ISO 9001, ISO 14001, EMC, MIC, WEEE, TELEC, REACH, NCC, iDA, MSIP, ICASA, TRA, Subtel
- OS Required
- Windows 8, Windows 8.1, Apple iOS 7 or later, Android 4.3 (Jelly Bean) or later, Windows Phone 8.1, Windows 10
- Rechargeable
- Installed Qty
- 1
- Required Qty
- 1
- Technology
- Lithium
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
