Design is in the details, and every one of them has been pored over for the keyboard. With the soft finish, it's the perfect complement to your device, and the finishing touch to a well-planned desk space. You'll love the solid feel of it under your fingers as you work. Thoughtfully engineered travel, height, pitch, and spacing help improve your typing speed and accuracy. Optimized feedback and return force prevents accidental presses and allows for smooth, consistent action. The key sound, stiffness, and texture provide a stable and quiet typing experience with optimized grip.
Complements your device
Design is in the details, and every one of them has been pored over for the keyboard. With the soft finish, it's the perfect complement to your device, and the finishing touch to a well-planned desk space. You'll love the solid feel of it under your fingers as you work. -
Get more done
Thoughtfully engineered travel, height, pitch, and spacing help improve your typing speed and accuracy. Optimized feedback and return force prevents accidental presses and allows for smooth, consistent action. -
Carefully crafted experience
- Microsoft Surface Keyboard - keyboard - British - grey
- Keyboard
- Interface
- Bluetooth 4.0
- Input Device
- Wireless
- Layout
- British
- Hot Keys Function
- Mute, play/pause, previous track, next track, volume -, volume +
- Grey
- 42.09 cm x 11.26 cm x 1.93 cm
- 419.3 g
- Pricing Type
- Commercial
- 1-year warranty
- Keyboard
- Interface
- Bluetooth 4.0
- Max Operating Distance
- Up to 15 m
Input Device
- Wireless
- Hot Keys Function
- Layout
- British
- 42.09 cm
- 11.26 cm
- 1.93 cm
- 419.3 g
- Grey
- AES
- Pricing Type
- Commercial
- OS Required
- Android 4.4.2 (KitKat) or later, Apple MacOS X 10.10.5 or later, Apple iOS 8.1 or later, Windows 8 / 8.1 / 10
- AAA type
- Installed Qty
- 2
- Required Qty
- 2
- Technology
- Alkaline
- Limited warranty - 1 year
