Microsoft Surface Pro LTE Core i5-7300 8GB 256GB SSD 12.3" Windows 10 Pro
Quicklinx: D8KSWS00 Mfr#: GWP-00002
Stock Status: Clearance, Used Stock
Sorry but this product has been discontinued.
View used stock
Create, study, work and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life plus a softer, ultra-portable design with rounded edges.
Microsoft Surface Pro - 12.3" - Core i5 7300U - 8 GB RAM - 256 GB SSD
Tablet - no keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i5 (7th Gen) 7300U / 2.6 GHz (3.5 GHz) / 3 MB Cache
8 GB LPDDR3
Storage
256 GB SSD
Display
12.3" touchscreen 2736 x 1824
Graphics
Intel HD Graphics 620
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1 wireless cellular modem
Wireless Broadband (WWAN)
4G
Up to 13.5 hours
Accelerometer, ambient light sensor, gyro sensor
Dockable
Security
Trusted Platform Module (TPM) Security Chip
29.2 cm x 20.1 cm x 0.85 cm
812 g
Region: United Kingdom, Ireland
Pricing Type
Commercial
Limited warranty - 1 year
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Max Turbo Speed
3.5 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
RAM
8 GB
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
256 GB SSD
Display
12.3"
Touchscreen
Yes (10-point multi-touch)
Resolution
2736 x 1824
Widescreen
Image Aspect Ratio
3:2
PixelSense
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Camera Features
Autofocus, Windows Hello
Sound
Stereo speakers, two microphones
Dolby Audio Premium
Communications
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Generation
4G
LTE Advanced
Navigation
Receiver
GPS/GLONASS
Run Time
Up to 13.5 hours
Connections & Expansion
USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , Dock , SurfaceConnect
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft Office 365 (30 days trial)
Integrated Options
Dockable
Security
Studio Mode
Power adapter
Localization
Pricing Type
Commercial
812 g
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: D8KS 040927
Condition: Customer return - item has been repaired under warranty by the manufacturer. Please Note: This item does not come in it's original packaging.
This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  £642.38
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Microsoft
Stock Status: Used Stock
Price Range Ex VAT: 500 - 750
