This is a commercial Surface Device and is intended for commercial use only.
Create, study, work and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life plus a softer, ultra-portable design with rounded edges.
A laptop in tablet form, Surface Pro brings together the best of Microsoft in one awesome new device.
Run all the same programs you have come used to with Windows 10. Run the full Office suite and your line of business applications and choose from thousands of apps available in the Windows Store. From The Economist to Wall Street Journal to Dropbox, you'll get amazing apps built specifically for Windows 10. Don’t forget to check back often for new and improved apps.
The Surface pro has all the fantastic security and manageability features that you expect from Microsoft. BitLocker encrypts your hard drive's data, helping to keep your stuff safe. Install applications and connect with accessories and printers, just like you always have. Join a corporate domain for full access to your work network.
Enjoy fast, powerful performance and stunning visuals. The Intel processor was built using the latest technologies, including HD graphics, to deliver with impressive speed and responsiveness.
A stunning entertainment experience awaits you with a 16:9 widescreen, ClearType full HD display with 1080p resolution. Movies and photos leap from the screen in bold color and sharp contrast. The Surface display is incredibly responsive to touch, pen and keyboard. Seamlessly switch between input modes in fluid motion.
Get creative with drawing and note taking in applications such as OneNote. Mark up your PowerPoint presentations, PDFs, and documents just like you would on paper.
Uncompromising mobility
Create, study, work, and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life, plus a softer, ultra-portable design with rounded edges. -
Exceptional power and performance
Surface Pro delivers even more speed and performance thanks to a powerful Intel i7 processor - with more battery life than Surface Pro 4 and 2.5x more performance than Surface Pro 3. -
A vibrant display that inspires creativity
Watch your ideas come to life in brilliant color and razor-sharp resolution on the 12.3" PixelSense display with a stunning screen that responds to the Surface Pen and touch. -
Whisper quiet
Surface Pro improved hybrid cooling on the i7 model, so you can work or stream your favorite shows in peace.
- Microsoft Surface Pro - 12.3" - Intel Core i7 - 7660U - 8 GB RAM - 256 GB SSD
- Product Type
- Tablet - no keyboard
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (7th Gen) - 7660U / 2.5 GHz, up to 4 GHz / 4 MB Cache
- Memory
- 8 GB LPDDR3
- Storage
- 256 GB SSD
- Display
- 12.3" touchscreen 2736 x 1824
- Graphics
- Intel Iris Plus Graphics 640
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 13.5 hours
- Accelerometer, ambient light sensor, gyro sensor
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip
- 29.2 cm x 20.1 cm x 0.85 cm
- 784 g
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Commercial
- Environmental Standards
- - EPEAT Climate+
- Specific Absorption Rate (SAR)
- 0.867 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (7th Gen) 7660U / 2.5 GHz
- Max Turbo Speed
- 4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- RAM
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 256 GB SSD
Display
- 12.3"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2736 x 1824
- Widescreen
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Camera Features
- Autofocus, Windows Hello
- Sound
- Stereo speakers, two microphones
- Dolby Audio Premium
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- Run Time
- Up to 13.5 hours
Connections & Expansion
- Interfaces Details
- USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , Dock , SurfaceConnect
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
Software
- Software Included
- Microsoft 365 (30 days trial)
- Integrated Options
- Dockable
- Security
- Studio Mode
- Included Accessories
- Power adapter
- SAR Value
- 0.867 W/kg (body)
- 0.867 W/kg (body)
- Localization
- Pricing Type
- Commercial
- 784 g
Sustainability Information
- TCO Certified
