Microsoft Surface Pro Core i7 7660U 16GB RAM 1TB SSD Windows 10 Pro
AVAILABLE NOW! UNCOMPROMISING MOBILITY WITH THE NEW SURFACE PRO
Quicklinx: CXJVWS00 Mfr#: FKL-00002
This is a commercial Surface Device and is intended for commercial use only.
Create, study, work and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life plus a softer, ultra-portable design with rounded edges.
A laptop in tablet form, Surface Pro brings together the best of Microsoft in one awesome new device.
Run all the same programs you have come used to with Windows 10. Run the full Office suite and your line of business applications and choose from thousands of apps available in the Windows Store. From The Economist to Wall Street Journal to Dropbox, you'll get amazing apps built specifically for Windows 10. Don’t forget to check back often for new and improved apps.
The Surface pro has all the fantastic security and manageability features that you expect from Microsoft. BitLocker encrypts your hard drive's data, helping to keep your stuff safe. Install applications and connect with accessories and printers, just like you always have. Join a corporate domain for full access to your work network.
Enjoy fast, powerful performance and stunning visuals. The Intel processor was built using the latest technologies, including HD graphics, to deliver with impressive speed and responsiveness.
A stunning entertainment experience awaits you with a 16:9 widescreen, ClearType full HD display with 1080p resolution. Movies and photos leap from the screen in bold color and sharp contrast. The Surface display is incredibly responsive to touch, pen and keyboard. Seamlessly switch between input modes in fluid motion.
Get creative with drawing and note taking in applications such as OneNote. Mark up your PowerPoint presentations, PDFs, and documents just like you would on paper.
  • Uncompromising mobility
    Create, study, work, and play virtually anywhere. Better than ever, ultra-light Surface Pro gives you total mobile productivity, all-day battery life, plus a softer, ultra-portable design with rounded edges.
  • Exceptional power and performance
    Surface Pro delivers even more speed and performance thanks to a powerful Intel i7 processor - with more battery life than Surface Pro 4 and 2.5x more performance than Surface Pro 3.
  • A vibrant display that inspires creativity
    Watch your ideas come to life in brilliant color and razor-sharp resolution on the 12.3" PixelSense display with a stunning screen that responds to the Surface Pen and touch.
  • Whisper quiet
    Surface Pro improved hybrid cooling on the i7 model, so you can work or stream your favorite shows in peace.
Microsoft Surface Pro - 12.3" - Intel Core i7 - 7660U - 16 GB RAM - 1 TB SSD
Tablet - no keyboard
Operating System
Win 10 Pro 64-bit
Intel Core i7 (7th Gen) - 7660U / 2.5 GHz, up to 4 GHz / 4 MB Cache
16 GB LPDDR3
Storage
1 TB SSD
Display
12.3" touchscreen 2736 x 1824
Graphics
Intel Iris Plus Graphics 640
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.1
Up to 13.5 hours
Accelerometer, ambient light sensor, gyro sensor
Dockable
Security
Trusted Platform Module (TPM) Security Chip
29.2 cm x 20.1 cm x 0.85 cm
784 g
Region: United Kingdom, Ireland
Pricing Type
Commercial
Environmental Standards
- EPEAT Climate+
0.867 W/kg (body)
Limited warranty - 1 year
Operating System
Windows 10 Pro 64-bit Edition
Processor / Chipset
CPU
Intel Core i7 (7th Gen) 7660U / 2.5 GHz
Max Turbo Speed
4 GHz
Number of Cores
Dual-Core
Cache
4 MB
64-bit Computing
RAM
16 GB
LPDDR3 SDRAM
Speed
1866 MHz
Storage
Main Storage
1 TB SSD
Display
12.3"
Touchscreen
Yes (10-point multi-touch)
Resolution
2736 x 1824
Widescreen
Image Aspect Ratio
3:2
PixelSense
Audio & Video
Graphics Processor
Camera
Yes - 1080p
Resolution
8 Megapixel (rear), 5 Megapixel (front)
Camera Features
Autofocus, Windows Hello
Sound
Stereo speakers, two microphones
Dolby Audio Premium
Communications
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
Run Time
Up to 13.5 hours
Connections & Expansion
Interfaces Details
USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , Dock , SurfaceConnect
Memory Card Reader
Yes (microSD, microSDHC, microSDXC)
Software
Software Included
Microsoft 365 (30 days trial)
Integrated Options
Dockable
Security
Studio Mode
Power adapter
SAR Value
0.867 W/kg (body)
0.867 W/kg (body)
Localization
Pricing Type
Commercial
784 g
Sustainability Information
TCO Certified
