Microsoft Surface Pen V3 - Red
Quicklinx: CB7ZWS00 Mfr#: 3XY-00032
You can use the Surface Pen to draw and take notes in apps. Mark up PowerPoint presentations, Adobe PDF files, or Word documents just as you would on paper. Or get creative and draw something in Fresh Paint - a drawing app available in the Windows Store. The Surface Pen can also be used like a mouse. Switch seamlessly between touch, pen, mouse, and keyboard. Palm block technology lets you write comfortably without worrying about your hand touching the screen.
  • Create without limits
    The Surface Pen is better and faster than ever, with precision ink on one end and a rubber eraser on the other - plus tilt for shading, greater sensitivity, and virtually no lag.
  • Think with ink
    Windows and Office give Surface Pen more power than ever. Strikethrough words to delete, circle text to select, highlight using Ink Editor - and even replay the sequence of mark-ups from others.
  • Easy note taking
    Taking and managing notes with OneNote is easier than ever. Do homework, replay notes to better remember your thoughts, and write out math equations that solve themselves using Ink Math Assistant - all in one place.
  • No printing required
    Streamline editing documents with digital inking. Use your Surface Pen to annotate and highlight text and the built-in digital ruler to set things straight.
  • Writes like pen on paper
    Surface Pen is a natural writing and drawing tool, with precision ink on one end that now enables tilt and a natural-feeling rubber eraser on the other.
  • 4,096 pressure points
    Sketch, shade, and paint with artistic precision and finer control with 4,096 pressure points that respond to the lightest touch.
  • Responds to an artist's touch
    Effortlessly express the finest sketches and lines with Surface Pen. Rest your hand on the screen of your Surface device, just as you would writing on a notebook.
Microsoft Surface Pen - v3 - active stylus - Bluetooth 4.0 - red
Active stylus
Bluetooth 4.0
Red
14.4 cm x 0.95 cm x 1.02 cm
20 g
Buttons Qty
2
Eraser, accelerometer gyroscopic control system, Palm Block technology
AAAA type
1-year warranty
Surface 3, Book, Book with Performance Base, Pro 3, Pro 4
Active stylus
14.4 cm
0.95 cm
1.02 cm
20 g
Red
Input Device
Bluetooth 4.0
Buttons Qty
2
Pressure Levels
1024
4 pen tips
AAAA type
Limited warranty - 1 year
Microsoft Surface 3, Book, Book with Performance Base, Pro 3, Pro 4
