You can use the Surface Pen to draw and take notes in apps. Mark up PowerPoint presentations, Adobe PDF files, or Word documents just as you would on paper. Or get creative and draw something in Fresh Paint - a drawing app available in the Windows Store. The Surface Pen can also be used like a mouse. Switch seamlessly between touch, pen, mouse, and keyboard. Palm block technology lets you write comfortably without worrying about your hand touching the screen.
Writes like pen on paper
Surface Pen is a natural writing and drawing tool, with precision ink on one end that now enables tilt and a natural-feeling rubber eraser on the other. -
4,096 pressure points
Sketch, shade, and paint with artistic precision and finer control with 4,096 pressure points that respond to the lightest touch. -
Responds to an artist's touch
Effortlessly express the finest sketches and lines with Surface Pen. Rest your hand on the screen of your Surface device, just as you would writing on a notebook.
- Microsoft Surface Pen - v3 - active stylus - Bluetooth 4.0 - black
- Active stylus
- Connectivity Technology
- Bluetooth 4.0
- Black
- 14.4 cm x 0.95 cm x 1.02 cm
- 20 g
- Buttons Qty
- 2
- Eraser, accelerometer gyroscopic control system, Palm Block technology
- Battery
- AAAA type
- 1-year warranty
- Designed For
- Surface Pro 4
- Active stylus
- 14.4 cm
- 0.95 cm
- 1.02 cm
- 20 g
- Black
Input Device
- Interface
- Bluetooth 4.0
- Buttons Qty
- 2
- Pressure Levels
- 1024
- Included Accessories
- 4 pen tips
- AAAA type
- Limited warranty - 1 year
- Designed For
- Microsoft Surface Pro 4
