Create without limits. The Surface Pen is better and faster than ever, with precision ink on one end and a rubber eraser on the other - plus tilt for shading, greater sensitivity, and virtually no lag.
The Surface Pen is better and faster than ever, with precision ink on one end and a rubber eraser on the other - plus tilt for shading, greater sensitivity, and virtually no lag. -
Think with ink
Windows and Office give Surface Pen more power than ever. Strikethrough words to delete, circle text to select, highlight using Ink Editor - and even replay the sequence of mark-ups from others. -
Easy note taking
Taking and managing notes with OneNote is easier than ever. Do homework, replay notes to better remember your thoughts, and write out math equations that solve themselves using Ink Math Assistant - all in one place. -
No printing required
Streamline editing documents with digital inking. Use your Surface Pen to annotate and highlight text and the built-in digital ruler to set things straight. -
Writes like pen on paper
Surface Pen is a natural writing and drawing tool, with precision ink on one end that now enables tilt1 and a natural-feeling rubber eraser on the other. -
4,096 pressure points
Sketch, shade, and paint with artistic precision and finer control with 4,096 pressure points that respond to the lightest touch. -
Responds to an artist's touch
Effortlessly express the finest sketches and lines with Surface Pen. Rest your hand on the screen of your Surface device, just as you would writing on a notebook.
- Microsoft Surface Pen M1776 - active stylus - Bluetooth 4.0 - poppy red
- Active stylus
- Connectivity Technology
- Bluetooth 4.0
- Poppy red
- 14.61 cm x 0.97 cm x 0.97 cm
- 20 g
- Buttons Qty
- 2
- Eraser
- Battery
- AAAA type
- Pricing Type
- Commercial
- 1-year warranty
- Designed For
- Surface Go 3
- Active stylus
- 14.61 cm
- 0.97 cm
- 0.97 cm
- 20 g
- Poppy red
Input Device
- Interface
- Bluetooth 4.0
- Buttons Qty
- 2
- Pressure Levels
- 4096
- Eraser
- Included Accessories
- AAAA battery
- Pricing Type
- Commercial
- AAAA type
- Limited warranty - 1 year
- Designed For
- Microsoft Surface Go 3
Microsoft Surface Pen Tip Kit 80 Pack | In Stock | £61.75 |
