This is a commercial Surface Device and is intended for commercial use only.
Surface Laptop provides the perfect blend of texture, subtle details, and clean, elegant lines - plus the luxurious touch of the Signature Alcantara material-covered keyboard. You don't have to choose between power and traveling light. At just 2.76 pounds, Surface Laptop gives you an ideal balance of both, plus all-day battery life.
- Microsoft Surface Laptop - 13.5" - Intel Core i5 - 7200U - 8 GB RAM - 128 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Windows 10 in S mode
- Processor
- Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
- Memory
- 8 GB LPDDR3
- Storage
- 128 GB SSD
- Display
- 13.5" touchscreen 2256 x 1504 - 201 ppi
- Graphics
- Intel HD Graphics 620
- Input Device
- Trackpad
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.1
- Battery
- Up to 14.5 hours
- Ambient light sensor
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Platinum
- 30.81 cm x 22.327 cm x 1.448 cm
- 1.252 kg
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Academic, commercial
- Specific Absorption Rate (SAR)
- 0.18 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Notebook
- Operating System
Processor / Chipset
- CPU
- Intel Core i5 (7th Gen) 7200U / 2.5 GHz
- Max Turbo Speed
- 3.1 GHz
- Number of Cores
- Dual-Core
- Cache
- 3 MB
- 64-bit Computing
- Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
- RAM
- 8 GB
- Technology
- LPDDR3 SDRAM
- Speed
- 1866 MHz
Storage
- Main Storage
- 128 GB SSD
Display
- 13.5"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 2256 x 1504
- Widescreen
- Pixel Density (ppi)
- 201
- Image Aspect Ratio
- 3:2
- Colour Gamut
- 100% sRGB
- Corning Gorilla glass 3, PixelSense
Audio & Video
- Graphics Processor
- Camera
- Yes - 720p
- Camera Features
- Windows Hello
- Sound
- Stereo speakers, stereo microphone
- Dolby Audio Premium
Input
- Keyboard, trackpad
- Keyboard Layout
- UK
- Soft-touch surface, multi-gesture trackpad
Communications
- Wireless
- Run Time
- Up to 14.5 hours
AC Adapter
- Output
- 44 Watt
Connections & Expansion
- Interfaces Details
- USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , SurfaceConnect (magnetic power and docking)
- Platinum
- Case Material
- Aluminum
- Integrated Options
- Dockable
- Security
- Included Accessories
- Power adapter
- SAR Value
- 0.18 W/kg (body)
- 0.18 W/kg (body)
- Localization
- Pricing Type
- 1.252 kg
Sustainability Information
- TCO Certified
