Microsoft Surface Dock for Surface Pro 3, Pro 4 and Surface Book
Quicklinx: BWVMWS00 Mfr#: PF3-00006
Turn your ultraportable Surface into a desktop PC and boost your productivity with Surface Dock.
Plug in the Surface Connect cable to charge your device and access external monitors, keyboard, mouse, and more. Find the perfect viewing angle, or position your device to take advantage of the robust pen capabilities.
With two high-definition video ports, a Gigabit Ethernet port, four high-speed USB 3.0 ports, and an audio output, you’ve got all the connections you need in a sleek, compact design.
Surface Dock uses Surface Connect technology which enables high-speed transfer of video, audio, and data over a single cable, keeping your desk clutter-free. It also has a Gigabit Ethernet port giving you a fast, reliable connection to your network.
Surface Dock is quick and easy to set up. Connect your peripherals to Surface Dock and then attach the magnetic Surface Connect cable to your device. It’s that easy.
2 Mini DisplayPorts 1 Gigabit Ethernet port 4 USB 3.0 ports 1 Audio out port Surface Connect cable External power supply
Microsoft Surface Dock - docking station - 2 x Mini DP - GigE
Docking station
Video Interfaces
2 x Mini DP
13 cm x 6 cm x 3 cm
550 g
Gigabit Ethernet
Power adapter
Pricing Type
Commercial
1-year warranty
Surface Book, Book 2, Book with Performance Base, Go, Laptop, Laptop 2, Laptop 3, Laptop 5 for Business, Laptop Studio, Pro (Mid 2017), Pro 3, Pro 4, Pro 6, Pro 7, Pro 9 for Business, Pro X
Docking station
13 cm
6 cm
3 cm
550 g
4 x SuperSpeed USB 3.0 , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x display / video - Mini DisplayPort , 1 x audio - line-out - mini-phone stereo 3.5 mm
1 x data cable - integrated
Security Slot Type
Kensington security slot
Pricing Type
Commercial
Power adapter
Limited warranty - 1 year
Microsoft Surface Book, Book 2, Book with Performance Base, Go, Laptop, Laptop 2, Laptop 3, Laptop 5 for Business, Laptop Studio, Pro (Mid 2017), Pro 3, Pro 4, Pro 6, Pro 7, Pro 9 for Business, Pro X
