Take advantage of this high-performance laptop designed for creative professionals on the go. The Microsoft Surface Book comes with a whopping 16GB RAM, speedy 512GB solid state drive and powerful 1GB NVIDIA graphics card.
Enjoy versatility at its best as the Surface Book comes in three configuration modes, enabling you to dictate how you work. If you need to use it like a traditional laptop, simply attach the keyboard. For those creative tasks, turn the screen around, or for easy use on the go, detach the keyboard and make use of the Surface Pen to prevent fingerprints smudging the screen and create a work of art.
The 13.5-inch touchscreen display comes with impressive 3000 x 2000 resolution so you can enjoy precision perfect image quality as you work. With up to 12 hours’ battery life, you won’t have to worry about losing power or forgetting your charger cable either.
The Surface Book weighs just 1.576kg making it your ideal companion for work on the go. Heighten the security with Windows Hello and the Trusted Module Platform security chip.
Connect instantly to the Internet with the 802.11n/ac wireless technology, while the Bluetooth 4.0 connectivity makes light work of data transfer.
Ultimate versatility
Surface Book transforms into three different configurations, adapting to the way that you work and the places where you create. -
Powerful laptop
Surface Book is a powerful laptop with a full sized, backlit keyboard for fast and natural typing. -
Portable clipboard
The 13.5" PixelSense display detaches easily from the keyboard to become a thin, light tablet that works perfectly with OneNote and Surface Pen. -
Creative canvas
Turn the screen around and reattach it to use Surface Book like a creative canvas. By reconnecting it to the keyboard, you unlock its full creative power in a pen first mode. -
Serious creativity
Use the multi-touch PixelSense screen and Surface Pen to create with all the desktop software you already use, like Adobe Photoshop and Illustrator. -
Mobile studio
Surface Book is the creative professional's laptop, designed to power through professional grade photo and video editing. -
Runs Windows & Office perfectly
The best Windows ever, with lots of features you'll love. Like innovations in security, personalization, and productivity. -
Full Office
Surface Book works perfectly with the full suite of Office products, driving your productivity to new heights. -
Markup webpages
Write directly on webpages with Surface Pen in the Microsoft Edge browser and share your notes easily. -
Limitless apps
Surface Book has all the power you'll need for even the most demanding creative apps. Use Adobe software3 with a pen or mouse.
- Microsoft Surface Book - 13.5" - Intel Core i7 - 6600U - 16 GB RAM - 512 GB SSD - UK
- Product Type
- Tablet - with keyboard dock
- Operating System
- Win 10 Pro 64-bit
- Processor
- Intel Core i7 (6th Gen) - 6600U / 2.6 GHz, up to 3.4 GHz / 4 MB Cache
- Memory
- 16 GB LPDDR3
- Storage
- 512 GB SSD
- Display
- 13.5" touchscreen 3000 x 2000
- Graphics
- NVIDIA GeForce 940M
- Video Memory
- 1 GB GDDR5 SDRAM
- Input Device
- Detachable keyboard, Surface Pen
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- Up to 12 hours
- Accelerometer, ambient light sensor, magnetometer, gyro sensor, hall sensor
- Dockable
- Security
- Trusted Platform Module (TPM) Security Chip
- Silver
- 31.23 cm x 23.21 cm x 2.28 cm
- 1.576 kg
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Commercial
- Environmental Standards
- - EPEAT Climate+
- Specific Absorption Rate (SAR)
- 0.72 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro 64-bit Edition
Processor / Chipset
- CPU
- Intel Core i7 (6th Gen) 6600U / 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- Dual-Core
- Cache
- 4 MB
- 64-bit Computing
- RAM
- 16 GB
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 512 GB SSD
Display
- 13.5"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 3000 x 2000
- Widescreen
- Image Aspect Ratio
- 3:2
- PixelSense
Audio & Video
- Graphics Processor
- Video Memory
- 1 GB GDDR5 SDRAM
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 5 Megapixel (front)
- Camera Features
- Autofocus, Windows Hello
- Sound
- Stereo speakers, two microphones
Input
- Keyboard Layout
- UK
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Run Time
- Up to 12 hours
Connections & Expansion
- Interfaces Details
- 2 x USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , 2 x SurfaceConnect
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Microsoft Office (30 days trial)
- Silver
- Case Material
- Magnesium alloy
- Integrated Options
- Dockable
- Security
- Included Accessories
- Keyboard
- SAR Value
- 0.72 W/kg (body)
- 0.72 W/kg (body)
- Localization
- Pricing Type
- Commercial
- 1.576 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Climate+
