Surface 3 Type Cover has the speed and functionality of a laptop keyboard. The click-in keyboard comes with bright, backlit keys. Enhanced with magnetic stability to keep the keyboard steady, you can work just as comfortably on your lap as at your desk.
Full keyboard capabilities
Thin and comfortable to use, Surface 3 Type Cover has the speed and ability of a classic laptop keyboard. Its keys are backlit, making it great for all-nighters. And it comes in eye-catching colors. -
Loaded and capable
Surface 3 Type Cover features a QWERTY keyboard, a full row of function keys (F1-F12), Windows shortcut keys, and media controls. Take control of the cursor with your fingertip using the built-in touchpad. -
Doubles as protection
When folded back, Surface 3 Type Cover keys disable to prevent unwanted typing while you're using your Surface 3. Flip Surface 3 Type Cover closed to turn the display off and shield the screen from bumps and scratches. -
Cool, like you
Surface 3 Type Cover is available in 5 colors, so you can show off how chic you truly are.
- Microsoft Surface 3 Type Cover - keyboard - QWERTY - UK - purple
- Keyboard
- Backlit
- Localization and Layout
- QWERTY UK
- Hot Keys Function
- Multimedia, Windows shortcuts
- Integrated touchpad, magnetic connection, accelerometer
- Purple
- 26.8 cm x 18.8 cm x 0.49 cm
- 265 g
- 1-year warranty
- Designed For
- Surface 3
- Keyboard
- Backlit
Input Device
- Hot Keys Function
- QWERTY UK
- Region
- United Kingdom, Ireland
- Keyboard Technology
- Mechanical
- 26.8 cm
- 18.8 cm
- 0.49 cm
- 265 g
- Purple
- Limited warranty - 1 year
- Designed For
