Microsoft Surface 3 Type Cover Black
Quicklinx: B8XBWS00 Mfr#: GV7-00011
Surface 3 Type Cover has the speed and functionality of a laptop keyboard. The click-in keyboard comes with bright, backlit keys. Enhanced with magnetic stability to keep the keyboard steady, you can work just as comfortably on your lap as at your desk.
  • Full keyboard capabilities
    Thin and comfortable to use, Surface 3 Type Cover has the speed and ability of a classic laptop keyboard. Its keys are backlit, making it great for all-nighters. And it comes in eye-catching colors.
  • Loaded and capable
    Surface 3 Type Cover features a QWERTY keyboard, a full row of function keys (F1-F12), Windows shortcut keys, and media controls. Take control of the cursor with your fingertip using the built-in touchpad.
  • Doubles as protection
    When folded back, Surface 3 Type Cover keys disable to prevent unwanted typing while you're using your Surface 3. Flip Surface 3 Type Cover closed to turn the display off and shield the screen from bumps and scratches.
  • Cool, like you
    Surface 3 Type Cover is available in 5 colors, so you can show off how chic you truly are.
Microsoft Surface 3 Type Cover - keyboard - QWERTY - UK - black
Keyboard
Backlit
Localization and Layout
QWERTY UK
Hot Keys Function
Multimedia, Windows shortcuts
Integrated touchpad, magnetic connection, accelerometer
26.8 cm x 18.8 cm x 0.49 cm
265 g
1-year warranty
Surface 3
Keyboard
Backlit
Input Device
Hot Keys Function
QWERTY UK
Region
United Kingdom, Ireland
Keyboard Technology
Mechanical
26.8 cm
18.8 cm
0.49 cm
265 g
Limited warranty - 1 year
Microsoft Surface 3
