Every aspect of Surface 3 has been meticulously crafted - from the strong, light frame with a 3-position Kickstand to the 10.8" high-resolution screen. Surface is elegant and durable enough to take everywhere.
Take notes, write directly on screen, and even record a lecture at the same time. With up to 10 hours of battery life for video playback, Surface 3 lasts through your movie marathon (or all your classes). Whether it's watching movies, managing your budget, or helping your child learn and play, Surface 3 has it covered. Feel more confident when your children are online with enhanced family safety settings. Surface 3 is the perfect travel companion.
A very thin and super-light Surface
The 622g Surface 3 is just the right size to slip under your arm or in your purse and take anywhere. -
Power through your day
Surface 3 has up to 10 hours of battery life for video playback so you can work, browse, play, or watch all day long. -
Work the way you want
With signature 3-position Kickstand, Surface 3 lets you binge watch your favorite shows hands-free. -
Mighty powerful
Surface 3 has a Quad-Core Intel Atom x7 processor, so it's fast, responsive and won't slow you down when you're on the go. -
Desktop software
Surface 3 runs all your Windows desktop software like Microsoft Office, iTunes, and Photoshop Essentials. -
Full-size USB 3.0
It is easy to connect all of your accessories with a full-size USB 3.0.
- Microsoft Surface 3 - 10.8" - Intel Atom x7 - Z8700 - 4 GB RAM - 64 GB SSD - 4G LTE
- Product Type
- Tablet - no keyboard
- Operating System
- Win 10 Pro
- Processor
- Intel Atom x7 Z8700 / 1.6 GHz, up to 2.4 GHz / 2 MB Cache
- Memory
- 4 GB LPDDR3
- Storage
- 64 GB SSD
- Display
- 10.8" touchscreen 1920 x 1280 / Full HD Plus
- Graphics
- Intel HD Graphics
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac wireless cellular modem
- Wireless Broadband (WWAN)
- 4G LTE
- Battery
- Up to 10 hours
- Ambient light sensor, proximity sensor
- Dockable
- 26.7 cm x 18.7 cm x 0.87 cm
- 622 g
- Localisation
- Region: United Kingdom, Ireland
- Pricing Type
- Commercial
- Specific Absorption Rate (SAR)
- 1.58 W/kg (body)
- Limited warranty - 1 year
- Product Type
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Intel 64 Technology, Intel AES New Instructions (AES-NI), Intel Burst Technology, Intel Identity Protection Technology
- RAM
- 4 GB
- Max RAM Supported
- 4 GB
- Technology
- LPDDR3 SDRAM
Storage
- Main Storage
- 64 GB SSD
Display
- 10.8"
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1920 x 1280 (Full HD Plus)
- Widescreen
- Image Aspect Ratio
- 3:2
- ClearType
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - 1080p
- Resolution
- 8 Megapixel (rear), 3.5 Megapixel (front)
- Camera Features
- Second camera
- Sound
- Stereo speakers, microphone
Communications
- Wireless
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, Bluetooth 4.0, IEEE 802.11ac
- Generation
- 4G
- Technology
- LTE
- Run Time
- Up to 10 hours
Connections & Expansion
- USB 3.0 , Mini DisplayPort , Headphone/microphone combo jack , Dock
- Memory Card Reader
- Yes (microSD, microSDHC, microSDXC)
- Integrated Options
- Dockable
- Accelerometer, magnetometer, gyroscope, 3-position Kickstand
- SAR Value
- 1.58 W/kg (body)
- 1.58 W/kg (body)
- Localization
- Pricing Type
- Commercial
- 622 g
