Product
Microsoft Sculpt Mobile Mouse (Wool Blue)
Quicklinx: CSS3WS00 Mfr#: 43U-00013
Wired / Wireless: Wireless
Colour: Wool blue
Compatibility: Android, Mac, PC
Hurry, only 2 left in stock!
£19.86 ex VAT
£23.83 inc VAT
Whether you're editing a presentation or connecting with friends online, Sculpt Mobile Mouse is a comfortable, familiar companion for your modern, mobile lifestyle. Its compact design and BlueTrack technology, which works on virtually any surface, make it the ideal device for the office or on the go. Enjoy a clutter-free workspace at your desk or on your coffee table with this wireless, mini-USB connected mouse.
The classic shape of Sculpt Mobile Mouse and its 4-way scroll wheel make it intuitive to operate with either hand. Tilting the wheel left and right allows you to scroll horizontally, performing such tasks as navigating the Start screen or moving through wide documents with ease.
Optimized for Windows
The Windows button on Sculpt Mobile Mouse is an exciting new feature that operates seamlessly with Windows. Simply press the Windows logo to instantly view the Start Menu and access all of your favorite apps, just one click away.
The perfect travel companion
Whether you’re editing a presentation or connecting with friends online, Sculpt Mobile Mouse is a comfortable, familiar companion for your modern, mobile lifestyle. Its compact design and BlueTrack technology, which works on virtually any surface, make it the ideal device for the office or on the go. Enjoy a clutter-free workspace at your desk or on your coffee table with this wireless, mini-USB connected mouse.
Familiar design, high functionality
  • Optimized for Windows
    The Windows button on Sculpt Mobile Mouse is an exciting feature that operates seamlessly with Windows 8. Simply press the Windows logo to instantly view the start screen and access all of your favorite apps, just one click away.
  • The perfect travel companion
  • Familiar design, high functionality
  • Four-way scrolling with tilt technology
    Scroll left, right, front and back with four-way wheel scrolling. Quickly navigate all of your projects with speed and efficiency.
  • Comfort and control for either hand
    A familiar oval shape and comfort focused design for either hand.
  • Perfect for travel
    It's compact design and wireless mini-USB connection makes it ideal for travel.
Microsoft Sculpt Mobile Mouse - mouse - 2.4 GHz - wool blue
Mouse
Wireless - 2.4 GHz
Wool blue
Orientation
Right and left-handed
5.69 cm x 9.53 cm x 4.05 cm
65 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 ppi
Performance
2400 fps
Scrolling wheel (4-way), Microsoft BlueTrack Technology
1 x AA type
Microsoft Windows 7, Windows 8, Microsoft Windows RT, Apple MacOS X 10.6 - 10.8
Microsoft Certification
Compatible with Windows 7
3 years warranty
Mouse
Wireless Receiver
Orientation
5.69 cm
9.53 cm
4.05 cm
65 g
Wool blue
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 5 m
Optical
Buttons Qty
3
Movement Resolution
1000 ppi
Performance
2400 fps
UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, EMC, MIC, FCC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO, China EIP
AA type
Alkaline
Installed Qty
1
Run Time (Up To)
11 months
Limited warranty - 3 years
5 - 80% (non-condensing)
Colour: Wool blue
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
