Microsoft Sculpt Ergonomic Wireless Keyboard and Keypad Set
Quicklinx: 9267WS00 Mfr#: 5KV-00002
Recommended Use: Leisure, Office
Type: Keyboard, Keypad
Wired / Wireless: Wireless
Compatibility: Mac, PC
More than 50 in stock
£64.93 ex VAT
£77.91 inc VAT
With its modern, ergonomic design, Sculpt Ergonomic Keyboard sets the standard for support and comfort. It keeps your hands and arms in a relaxed position as you work, helping you feel refreshed after a day at your desk without soreness or injury.
Sculpt Ergonomic Keyboard is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest that protects against inflammation and repetitive stress injuries. The domed keyboard shape works to reduce and correct excessive wrist pronation that can cause pain and limited mobility.
The natural arc layout follows the curve of your fingertips for a more natural way of typing. The reverse-tilt design positions the keyboard at the correct angle to give you a neutral wrist position.
  • Unique design for comfort and functionality
  • Protection for your joints
  • Following the body's natural lines
Microsoft Sculpt Ergonomic Keyboard For Business - keyboard and keypad set - UK
Keyboard and keypad set - ergonomic
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard - wireless
Layout
Keys Qty
105
Hot Keys Function
Volume, mute, play/pause
Split spacebar with backspace functionality
Pointing Device
Keypad
3-year warranty
2.4 GHz
Max Operating Distance
Up to 3 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 39.2 cm x 22.8 cm x 5.9 cm / 836 g , Keypad: 9.28 cm x 13.2 cm x 1.17 cm / 100 g
Input Device
Keyboard - wireless
Keys Qty
105
Hot Keys Function
Layout
Pointing Device
Keypad
UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, MIC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO
Microsoft Windows 7, Windows 8, Microsoft Windows RT
AAA type
Installed Qty
2
Required Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Recommended Use: Office
Type: Keyboard
Type: Keypad
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 50 - 100
