Sculpt Ergonomic Desktop is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest to provide wrist support. The domed keyboard shape works to reduce and correct wrist pronation that can cause pain and limited mobility.
Sculpt Ergonomic Desktop is designed for productivity, with an eye on ergonomic excellence. By providing a relaxed, comfortable computing experience, it enables you to work without the stress, strain, and discomfort of other keyboards and mice you may have used in the past.
Advanced ergonomic design
Sculpt Ergonomic Desktop is built on advanced ergonomic principles, with a split keyboard layout that keeps wrists and forearms in a relaxed position, and a cushioned palm rest to provide wrist support. The domed keyboard shape works to reduce and correct wrist pronation that can cause pain and limited mobility. -
True comfort for lasting productivity
Sculpt Ergonomic Desktop is designed for productivity, with an eye on ergonomic excellence. By providing a relaxed, comfortable computing experience, it enables you to work without the stress, strain, and discomfort of other keyboards and mice you may have used in the past. -
It's all in the angles
The natural arc keyboard layout follows the curve of your fingertips for a more natural way of typing. Reverse tilt design positions the keyboard at the correct angle to give you a straight, neutral wrist position. Additionally, the shape of the mouse is designed for maximum wrist comfort.
- Microsoft Sculpt Ergonomic Desktop - keyboard, mouse and numeric pad set - English - United Kingdom
- Keyboard, mouse and numeric pad set - ergonomic
- Interface
- 2.4 GHz
- Wireless Receiver
- USB wireless receiver
- Input Device
- Keyboard - wireless
- Layout
- Keys Qty
- 105
- Hot Keys Function
- Volume, mute, play/pause
- Removable palm rest, split spacebar with backspace functionality
- Pointing Device
- Mouse - optical
- Buttons Qty
- 3
- Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab
- 3-year warranty
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 3 m
- Wireless Receiver
- Dimensions (WxDxH) / Weight
- Keyboard: 39.2 cm x 22.8 cm x 5.9 cm / 842 g , Mouse: 7.94 cm x 9.82 cm x 5.67 cm / 155 g , Keypad: 9.28 cm x 13.2 cm x 1.17 cm / 106 g
Input Device
- Keyboard Name
- Microsoft Sculpt Ergonomic Keyboard
- Keys Qty
- 105
- Hot Keys Function
- Layout
Pointing Device
- Mouse
- Pointing Device Name
- Microsoft Sculpt Ergonomic Mouse
- Buttons Qty
- 3
- Movement Detection Technology
- Optical
- Pointing Device Features
- UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, CB, RSS-210, MIC, NTRA, KCC, WEEE, ANATEL, TELEC, URSEC, REACH, UkrSEPRO
- OS Required
- Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 8.1 RT, Windows 10 (32/64 bits), Apple MacOS X 10.7 or later (limited functionality), Microsoft Windows 7 (32/64 bits) (limited functionality)
- Installed Qty
- 2
- Required Qty
- 2
- Technology
- Alkaline
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 80% (non-condensing)
