Microsoft Sculpt Comfort Desktop
Maximum comfort - customised for you!
Quicklinx: 92YMWS00 Mfr#: L3V-00006
Recommended Use: Leisure, Office
Type: Keyboard, Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
17 in stock
£46.58 ex VAT
£55.89 inc VAT
Maximum comfort, customized for you
With its contoured design, customizable features that easily adjust to your needs, and a specially designed, right-handed mouse, Sculpt Comfort Desktop transforms the way you use a keyboard and mouse. It helps you keep your wrists in a neutral position, while providing functionality and shortcuts that improve typing efficiency.
Modern modular design
The sleek design and comfort curve layout keep keys within easy reach, while straightening wrists with ergonomic palm support that protects against inflammation and repetitive stress injuries. The split spacebar offers new backspace functionality to help you make the most of your keystrokes. Tight workspace? Sculpt Comfort Desktop can be easily customized to save space, and offer a more compact look, by detaching the palm rest.
Windows 8 integration
Sculpt Comfort Desktop perfectly integrates with Windows 8. The keyboard hotkeys provide shortcuts to the most commonly used keyboard functions. The Windows Touch tab, a touch-sensitive strip located on the side of the mouse, enables you to take advantage of swiping functionality as you navigate the Start screen.
  • Maximum comfort, customized for you
  • Modern modular design
    The sleek design and comfort curve layout keep keys within easy reach, while straightening wrists with ergonomic palm support that protects against inflammation and repetitive stress injuries. The split spacebar offers backspace functionality to help you make the most of your keystrokes. Tight workspace? Sculpt Comfort Desktop can be easily customized to save space, and offer a more compact look, by detaching the palm rest.
  • Windows 8 integration
Microsoft Sculpt Comfort Desktop - keyboard and mouse set - English - United Kingdom
Keyboard and mouse set - ergonomic
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard - wireless
Layout
Keys Qty
105
Hot Keys Function
Calculator, volume, search, mute, play/pause
Removable palm rest, battery LED indicator, split spacebar with backspace functionality
Pointing Device
Mouse - optical
Buttons Qty
3
Scrolling wheel (4-way), BlueTrack Technology, right-handed, Windows touch tab
3-year warranty
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 45.3 cm x 21.3 cm x 3.3 cm / 807 g , Mouse: 6.85 cm x 11.1 cm x 3.65 cm / 135 g
Input Device
Keyboard - wireless
Keyboard Name
Microsoft Sculpt Comfort Keyboard
Keys Qty
105
Hot Keys Function
Layout
Pointing Device
Mouse
Pointing Device Name
Microsoft Sculpt Comfort Mouse
Buttons Qty
3
Movement Detection Technology
Optical
Pointing Device Features
UL, VCCI, BSMI, ISO 9001, GOST, cUL, ISO 14001, WHQL, CB, RSS-210, IC, MIC, FCC, NTRA, AES-128, KCC, WEEE, ACA, ANATEL, TELEC, URSEC, UkrSEPRO
Microsoft Windows 7, Apple MacOS X 10.4 or later, Windows 8, Microsoft Windows RT
Installed Qty
2
Required Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Recommended Use: Office
Type: Keyboard
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
