High-end features, premium design, and the best Windows 10 experience – get the phone that works like your PC and turn an ordinary moment into your biggest accomplishment.
Powered by Windows 10
Discover the benefits of one Windows experience. Office apps and Outlook Mail have familiar rich editing tools that scale to fit the screen you're using and the brand new Windows Store makes it easy to find apps, music, and videos. And with Cortana for Windows 10, you can use your PC to set a location-based reminder that will arrive just in time on your Lumia. -
Built to do great things
Unleash the potential of your digital life with a stunning Quad HD display. Run the most demanding apps without missing a beat and power up quickly with USB-C Fast Charging. With a super-fast processor, a large capacity battery, and wireless charging, the Lumia 950 has the power and performance that you'd expect from a premium smartphone. -
Perfect pictures
With powerful camera features like Rich Capture, a triple LED natural flash, and a 20 MP sensor that has been engineered to virtually eliminate motion blur, you'll have the confidence to capture anything. Want your pictures in sync across devices? -
Windows Continuum
Connect your Lumia 950 to a Microsoft Display Dock and use it with an external monitor, a keyboard, and a mouse. Office apps and Outlook scale up to create a big screen-optimized work environment that makes you more productive. It's a PC-like experience that's powered by your phone.
- Microsoft Lumia 950 - white - 4G smartphone - 32 GB - GSM
- Product Type
- 4G smartphone
- Display
- OLED display - 2560 x 1440 pixels - 5.2" - 564 ppi - AMOLED - Corning Gorilla Glass 3 (scratch resistant glass)
- FM radio
- Processor
- Qualcomm Snapdragon 808 1.8 GHz (6-core) - 64-bit
- Memory
- RAM 3 GB / 32 GB
- Supported Memory Card
- microSDXC slot - up to 200 GB
- Operating System
- Windows 10
- Main Camera
- 20 Megapixel - BSI 26 mm - f/1.9 - focus: automatic, motorised
- Front Camera
- 5 Megapixel - wide-angle lens - f/2.4
- Service Provider
- Not specified
- SIM Card
- Nano SIM
- Wireless Interface
- NFC, Wi-Fi 5, Bluetooth
- Messaging Services
- Skype, WhatsApp, SMS, MMS
- Connectors
- 3.5 mm headset jack, USB-C
- Talk Time
- Up to 1380 minutes
- Standby Time
- Up to 288 hours
- Wireless Charging Standards
- Qi
- White
- 73.2 mm x 8.2 mm x 145 mm
- 150 g
- Specific Absorption Rate (SAR)
- 0.48 W/kg (head) , 0.6 W/kg (body)
- 2-year warranty
- Product Type
- Smartphone
- Form Factor
- Touch
- Integrated Components
- FM radio
- 73.2 mm
- 8.2 mm
- 145 mm
- 150 g
- Body Colour
- White
- SAR Value
- 0.6 W/kg (body), 0.48 W/kg (head)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Operating System
- Windows 10
- Intelligent Assistant
- Cortana
- Navigation
- A-GPS, GLONASS, BeiDou
- SIM Card Type
- Nano SIM
- Input Device
- Multi-touch
Messaging & Internet
- Supported Social Networks and Blogs
- Twitter, Facebook, LinkedIn
Communications
- Data Transmission
- GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE
- 2G Band
- 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 4G LTE Band
- Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 17, Band 20, Band 28, Band 38, Band 40, Band 41
- 4G LTE Frequency
- FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700b, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300, TDD 2500
- NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.1
- WLAN Security
- WEP, WPA, WPA2, TKIP, AES, EAP SIM, EAP-TTLS/MSCHAPv2, EAP-AKA, EAP-TLS, PEAPv0/EAP-MSCHAPv2
- Bluetooth Profiles
- HFP, OPP, PAN, A2DP, AVRCP, HID, PBAP, MAP, GATT, HOGP
Phone Features
- Phone Functions
- Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert
- Sensors
- Accelerometer, ambient light sensor, proximity sensor, barometer, magnetometer, gyro sensor
- Additional Features
- TTY compatible, DLNA Certified, Text-to-Speech (text recognition), sharing media via DLNA, Kid's Corner, Noise Cancellation Technology, Lumia Color profile, MIMO technology, Word Flow keyboard, Power Saving Mode, Wi-Fi Calling, four microphones, SensorCore technology, Projection Screen, Alarm Clock
Media Player
- Supported Digital Audio Standards
- AAC, AMR, MP3, GSM FR
- Supported Digital Video Standards
- VC-1, AVC, MPEG-4, WMV, H.264, H.263
- Clock Speed
- 1.8 GHz
- Processor Core Qty
- 6-core
- 64-bit Architecture
- RAM
- 3 GB
- Internal Memory Capacity
- 32 GB
- Supported Flash Memory Cards
- microSDHC, microSDXC - up to 200 GB
Front Camera
- Sensor Resolution
- 5 Megapixel
- Lens Type
- Wide-angle lens
- Lens Aperture
- F/2.4
- Video Resolutions
- 1920 x 1080 (1080p)
Main Camera
- Sensor Resolution
- 20 Megapixel
- Sensor Type
- BSI
- Optical Image Stabiliser
- Optical Image Stabiliser (OIS)
- Lens Aperture
- F/1.9
- Lens Construction
- 6-element
- Min Focal Length
- 26 mm
- Focus Adjustment
- Automatic, motorised
- Light Source
- LED light
- Video Resolutions
- 3840 x 2160 (4K)
- PureView technology, Fast AF
Display
- OLED display
- Technology
- AMOLED
- Diagonal Size
- 5.2"
- Display Resolution
- Display Format
- QHD
- Pixel Density
- 564 ppi
- Colour Depth
- 16.7 million colours
- Protection
- ClearBlack
- Connector Type
- USB Type-C - 24 pin USB-C , Headset jack - mini-phone 3.5mm
- Technology
- Lithium Ion
- Capacity
- 3000 mAh
- Wireless Charging
- Qi
- Talk Time
- 1380 minutes
- Standby Time
- 288 hours
- Run Time Details
- Talk (GSM): up to 1380 min , Talk (WCDMA): up to 1080 min , Playback (video): up to 10 hrs , Playback (Music): up to 67 hrs , Active online usage (Wi-Fi): up to 9.5 hrs , Standby: up to 288 hrs
- SSL v3, TLS v1.2, TLS v1.0, TLS v1.1, Suite B ciphers
- Included Accessories
- USB cable, power adapter
- Limited warranty - 2 years
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.07 |
