Microsoft LifeChat LX-4000 for Business - headset
MICROSOFT LYNC OPTIMISED
Quicklinx: 7T2HWS00 Mfr#: 7YF-00001
You can tune in online and in life. The single earpiece lets you hear what's going on around you and still take care of business - whether that is making video calls or listening to music while working. The ultra-wideband digital audio provides clear, accurate sound. The highly sensitive, noise canceling microphone gives you the confidence that you are being heard even when you're surrounded by a noisy work environment.
  • Selective sound
    Single earpiece lets you hear everything you need to hear.
  • Noise canceling microphone
    Your voice will clearly cut through, and you can easily select your position.
  • In-line volume and microphone controls
    Adjust volume or mute on the fly with handy in-line controls.
  • Plug-and-play simplicity
    No software is needed, just plug it in and you're ready.
  • Comfortable
    You'll forget you're wearing it. And the call indicator light lets people know you're "busy".
Headset - wired
Recommended Use
Computer
Headphones Form Factor
Full size
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute, volume
Microsoft Certification
Compatible with Windows 7
3-year warranty
Headset - wired
Recommended Use
Computer
Audio Output
Full size
Wired
Sound Output Mode
Mono
Microphone
Boom
Remote Control
Controls
Mute, volume
Connector Type
Headset (4 PIN USB Type A)
Limited warranty - 3 years
Resources
The following resources are available for the Microsoft LifeChat LX-4000 for Business - headset
