Take your productivity to the next level with the Surface 3 Docking Station. Instantly transform your ultra-portable Surface 3 into a desktop PC and easily connect to your favorite accessories.
Connect to your HD monitor, wired network, audio system, full-size keyboard, printer and more, while charging your Surface 3 and accessories.
Instant office
Just click your Surface 3 into the dock to go from tablet to full desktop PC - it's that simple. It has all the ports you need, so you can attach a monitor, keyboard, printer, and more. -
Mini DisplayPort video output
The mini DisplayPort connection delivers high-definition video resolution of 3840 x 2600 DPI. -
USB ports
Docking Station has four USB ports - two USB 3.0 and two USB 2.0. So it's easy to transfer large files to an external drive, connect to a USB printer or headset, and charge multiple accessories as you work. -
Gigabit Ethernet port
The gigabit Ethernet connection is lightning fast, with data transfer rates of 1 billion bits per second. Downloads fly and uploads soar. -
All powerful
The 48-watt power supply quickly recharges your Surface 3 battery and all your favorite devices while you work. That way you can hit the road or race to class with a fully charged device.
- Microsoft - docking station - Mini DP - GigE
- Product Type
- Docking station
- Video Interfaces
- Mini DP
- 31.1 cm x 14 cm x 9.5 cm
- 800 g
- Networking
- Gigabit Ethernet
- 1-year warranty
- Designed For
- Surface 3
- Product Type
- Docking station
- 31.1 cm
- 14 cm
- 9.5 cm
- 800 g
- Data Link Protocol
- 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x display / video - Mini DisplayPort , 1 x audio - line-In - mini-phone stereo 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm
- Security lock slot (cable lock sold separately), pen holder
- Security Slot Type
- Kensington security slot
- Limited warranty - 1 year
- Designed For
- Microsoft Surface 3
