Microsoft Desktop 850 Wireless Keyboard and Mouse set
ENJOY THE FREEDOM OF WIRELESS TECHNOLOGY!
Quicklinx: BYGHWS00 Mfr#: PN9-00005
Wired / Wireless: Wireless
Compatibility: Mac, PC
Stock Status: Clearance
More than 50 in stock
£24.52 ex VAT
£29.42 inc VAT
Enjoy the freedom and convenience of wireless technology. Confidently roam up to 15 feet away from your PC while maintaining a strong wireless connection. Or, take the mouse separately to use with a laptop while traveling - the tiny transceiver conveniently snaps into the bottom of the mouse when it's time to pack up and go. Setting up the keyboard and mouse is simple - just insert the batteries, plug in the tiny transceiver, and start typing! This keyboard also has Advanced Encryption Standard (AES), which is designed to help protect your information by encrypting your keystrokes.
  • Reliable wireless connection
    Enjoy the 2.4-gigahertz (GHz) wireless technology, which delivers a reliable connection with up to a 15 foot range, with virtually no interference.
  • Advanced Encryption Standard (AES) 128-bit encryption
    This keyboard features Advanced Encryption Standard (AES) technology, which is designed to help protect your information by encrypting your keystrokes. Each keyboard is permanently paired with its receiver at the factory - no key information is ever shared over the air.
  • Windows shortcut keys
    Quickly access frequently used tools, like the calculator, zoom and audio controls by using shortcut keys.
  • Designed for comfort
    In either hand Superior comfort that's designed to fit your right or left hand.
  • Microsoft optical technology
    Precise optical tracking technology provides highly responsive cursor control.
  • Snap-in transceiver
    Plug the wireless receiver into your computer's USB port when you're ready to work. Then snap it into the bottom of your mouse when you travel, and the mouse will automatically turn off.
  • Battery life indicator
    Avoid getting caught with a dead battery. The battery status indicator glows red when the battery is running low.
  • Scroll wheel
    Move through documents and webpages quickly.
  • Power switch
    Turn off your mouse to extend battery life.
  • Windows start screen key
    Simply press the Windows start screen key to view your apps and start screen.
  • Longer battery life
    Experience fewer interruptions with up to 15 months of battery life for your keyboard.
Microsoft Wireless Desktop 850 for Business - keyboard and mouse set
Keyboard and mouse set
2.4 GHz
Wireless Receiver
USB wireless receiver
Input Device
Keyboard - wireless
Hot Keys Function
Calculator, volume, mute, play/pause, Windows 8, Start key
Pointing Device
Mouse - wireless - optical
Buttons Qty
3
3-year warranty
2.4 GHz
Wireless Receiver
Dimensions (WxDxH) / Weight
Keyboard: 48.6 cm x 22.7 cm x 4.57 cm / 601 g , Mouse: 5.83 cm x 11.3 cm x 3.96 cm / 65.9 g , Wireless receiver: 2.76 cm x 1.5 cm x 0.689 cm / 2.8 g
Input Device
Keyboard - wireless
Keyboard Name
Microsoft Wireless Keyboard 850
Hot Keys Function
Pointing Device
Mouse - wireless
Pointing Device Name
Microsoft Wireless Mouse 1000
Buttons Qty
3
Movement Detection Technology
Optical
Included Software
Drivers & Utilities
Microsoft Windows 7, Apple MacOS X 10.4 - 10.7, Windows 8, Windows 10
AAA type
Installed Qty
2
Alkaline
Limited warranty - 3 years
5 - 80% (non-condensing)
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
