Microsoft Compact Optical Mouse 500 for Business
Quicklinx: 7CWYWS00 Mfr#: 4HH-00002
This affordable, compact mouse with Microsoft Optical technology is an ideal companion for on the go notebooks where work space is at a premium. It delivers precise cursor control on a wide variety of surfaces, and is comfortable in either hand.
Easy to Set Up and Use
Avoid installing software and setting up features.
Compact
Easily carry and use on small workspaces.
Comfortable in Either Hand
Use your mouse with your left or right hand. Ambidextrous design makes it comfortable either way.
Scroll Wheel
Navigate through documents and webpages quickly without using the on-screen scroll bar.
Optical Technology
Enjoy high-performance optical technology. The 800-dots-per-inch (DPI) optical sensor delivers greater accuracy and control.
Device Stage
Quickly and easily access common tasks, including product information, registration, settings, and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard, and webcam products.
Three-Button Mouse
Get quick access to the media, programs, and files you use most often.
Two-Year Warranty
  • Easy to set up and use
    No software to install, no feature setup required.
  • Compact
    Easy to carry along and use on small work spaces.
  • Comfortable in either hand
    Use your mouse with your left or right hand - ambidextrous design makes it comfortable either way.
  • Scroll wheel
    Move through your documents quickly without having to click on the on-screen scroll bar.
  • Optical technology
    800-dpi optical sensor delivers greater accuracy and control.
  • Device stage
    Quickly and easily access common tasks, including product information, registration, settings and more for popular devices such as cell phones, cameras, printers, and mouse, keyboard and webcam products.
  • 3-button mouse
    Get quick access to the media, programs, and files you use most often with customizable buttons.
Microsoft Compact Optical Mouse 500 for Business - mouse - USB - black
Mouse
Wired - USB
Orientation
Right and left-handed
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
Apple MacOS X 10.2, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
Orientation
Input Device
Wired
USB
Optical
Buttons Qty
3
Movement Resolution
800 dpi
Scrolling wheel
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 3 years
