Microsoft Comfort Mouse 4500 - optical - 5 button - USB - black
Quicklinx: 8X88WS00 Mfr#: 4fd-00023
Type: Mouse
Wired / Wireless: Wired
Colour: Black
Compatibility: Mac, PC
More than 50 in stock
£14.15 ex VAT
£16.98 inc VAT
Work anywhere with this full-featured mouse, which delivers comfort in either hand and the precise control of Microsoft BlueTrack Technology at a great value.
  • BlueTrack Technology
    Microsoft BlueTrack Technology combines the power of optical with the precision of laser for remarkable tracking on virtually any surface.
  • Comfort and durability
    Rubber side grips and a contoured shape for either hand. Dust-resistant design allows you to track confidently.
  • 5 customizable buttons
    Reassign any button to fit your needs. Quick access to the media, programs, and files you use most often.
  • Tilt wheel
    Easy horizontal and vertical scrolling.
Microsoft Comfort Mouse 4500 - mouse - USB - black
Mouse
Wired - USB
6.79 cm x 11.6 cm x 4.23 cm
131 g
Movement Detection Technology
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
Performance
8000 fps
Scrolling wheel, Tilt Wheel technology, rubber side grips, Microsoft BlueTrack Technology
1 x USB cable - integrated - 1.93 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.4 - 10.6
Microsoft Certification
Compatible with Windows 7
3-year warranty
Mouse
6.79 cm
11.6 cm
4.23 cm
131 g
Input Device
Wired
USB
Optical
Buttons Qty
5
Movement Resolution
1000 dpi
Performance
8000 fps
1 x USB - 4 pin USB Type A
UL, VCCI, BSMI, ISO 9001, ICES-003, ISO 14001, CB, FCC, KCC, WEEE, ACA; USB 2.0
Limited warranty - 3 years
5 - 80% (non-condensing)
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Microsoft
Price Range Ex VAT: 0 - 50
